Walbro 255 vs DW301 on factory fuel pump wiring
#34
so what power level are you having these issues at?
i will be running 380-400whp (hopefully), using fic 1100's with possible/occasional e85 use. i had my hopes up that i could use the dw pump as a drop in due to how loud my previous walbros have been in other cars.
but this is starting to make me question that...
awesome info/testing as usual.
#35
#36
so is your take at this point that if not trying to max out the pump, the dw has the potential to be at least equivalent to a 255? thats the biggest question i havent seen evidence towards.
maybe i just need to go bigger so the data applies
#37
I ran out of fuel with the Walbro HP 255 on E-85 and 1450cc FIC Bluemax Injectors at a little over 500whp on VD (Dynojet Setting). That was on the factory fuel pump wiring. If you are talking 380-400 Dynojet AWHP the Walbro HP 255 will get you there.
Dan (drb)
#38
I don't have enough info yet to say whether one does better than the other with a rewire.
Either one can support the power level that you mentioned with E85.
#39
I am anxiously awaiting the results of your Walbro 400 testing. Are you going to test it on the stock wiring and also with a rewire? I have a 400 installed on the stock wiring, but I'm waiting to get retuned until I can determine if a rewire is needed to support approx. 525HP on E-85.
Dan (drb)
Dan (drb)
#40
Dan (drb)
Dan (drb)
#41
Well, i dont know what u guys are on about...i put in a DW301 pump and without any changes to anything else..went from AFR's of 12's to 10.8 to 11........had to re tune it because it was running too rich and missing at spool...Also , i haven't even re-wire the pump yet....
#42
Ive done maybe 3 cars (ok maybe more) with DW300's and they all were the same results as mrfred sees here so i dont know what you're going on about saad601.
mrfred's tests are all done 100% on the money so if he says something listen to it.. dont question it.
#43
Dan (drb)
Dan (drb)
#45
i can remember 3 customers off the top of my head who we had issues with after swapping to the dw300 pump.. Dw claimed it was from the oring not being sealed right on the pump, sent my customer a new oring, still same thing didnt fix it..
the pump just cant compete with the walbro 255. id be interested to see how it does once it sees full voltage.
