Vendor Service / Parts / Tuning Review Post your service, part & tuning reviews here. Please note all new threads are moderated.
Competition clutch bad clutch kits (cheap quality)
Old Nov 19, 2018, 02:42 PM
  #31
GSX_TO_EVO's Avatar
Originally Posted by vette557
You probably didn’t have a Evo 6 Tommi Makinen built at your garage . So maybe it’s a different case here .
How does this make any relevance to why your flywheel bolts keep backing out?
Old Nov 19, 2018, 03:00 PM
  #32
vette557's Avatar
[QUOTE=GSX_TO_EVO;11849416]
[/QUOT
Theres a difference in the transmission and he says that he’s a mechanic that he work on a lot of evos with com clutch “SINGLE plate discs”
Old Nov 19, 2018, 03:01 PM
  #33
vette557's Avatar
Would the bolt holes wallow up because of the weight of the flywheel it weighs about 18lbs-20lbs not sure but that’s approximate when I tried to ship it back to them.
Old Nov 19, 2018, 03:15 PM
  #34
Pal215's Avatar
I thought this thread got closed.
The bolt holes shouldn't be misshapen at all as long as the flywheel bolts stay tight. Once they loosen up, it gives any flywheel, no matter how light, enough room to widen the bolt holes. The flywheel bolts really only help transfer the load from the big end face of the crank to the inner face of the flywheel. When the bolts get loose, the face to face contact friction disappears and then all the load is transferred to the flywheel bolts themselves. After that you have nothing but the shear (side loading) strength of the bolt to help you out. Thus, the flywheel bolts will begin to eat at the metal around the flywheel bolt holes.
Old Nov 19, 2018, 03:25 PM
  #35
vette557's Avatar
The fly wheel is very heavy it’s 3 1/2 times heavier than the Oem one and there is one matter that I forgot about where the flywheel faces the crank there is like a slight depth where it should sit having it compared with the oem flywheel it’s half less deeper than the Oem .
Old Nov 19, 2018, 04:02 PM
  #36
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
It's a 7 bolt 4g63, nothing special about it.
The lip that fits over the crank flange only needs to be enough to keep the flywheel centered while you torque the bolts. Once the bolts are tight, just like the wheel and wheel bearing hub, the friction of the mating surface is what holds it together.
The comp flywheel is heavy rotational inertia, it helps make the car easier to launch. I've installed a few of the twins also. The damage you are seeing is loose flywheel bolts. Plain and simple. Why its happening? You should consult a new shop because the one doing the work clearly isn't doing something right.
