MAP Race Prepped Evo 8 Long Block with MAP Dry Sump Kit
Main components: MAP Stage 2 2.1L Shortblock and MAP Stage 5 Head with MAP Dry Sump Kit This engine was built for the 2014 season but, due to our hectic schedule, the car never actually made a single pass through the season. This engine was run on the dyno for to clean up the tune after the rebuild and has approximately 10-14 full power pulls as a result. The engine was also used to do some R&D testing that required some additional lighter power pulls. After concluding the most recent tuning session, the crank was removed and an OEM 88mm crank, precision polished and balanced, was installed with new ACL Race Bearings. This engine is now complete, ready to drop in and includes the following components: MAP Stage 2 2.1 Liter Shortblock with Core: (Retail: 3624.99) Wiseco Pistons: K626M87AP: Wiseco 1400HD 87MM Piston Set 9.8:1 Compression Ratio MAP 156MM Rev2 Ultimate Duty Connecting Rods OEM Mitsubishi Crank - Precision polished and balanced ACL Race Bearings MAP Water Pump Adapter Plate MAP Supplied OEM Mitsubishi 4G64 Block with OEM 4G63 Crank MAP Stage 5 EVO 8 Head with Core: (Retail: 3282.44) Combustion Chambers matched to 87mm 4G64 Block Supertech +1mm Intake Valves with +1mm Inconnel Exhaust Valves Supertech Valve Seals Ferrea Valve Guides GSC Springs and Retainers MAP Supplied Core MAP Exhaust Manifold and Stud Kit MAPerformance Dry Sump System for Evolution 8 & 9 (Retail: 4240.99) Longblock components: Valve Cover: (Retail: 459.38) AEM Adjustable Cam Gears: (Retail: 130.27 x 2 = 260.54) MAP Timing Belt Kit with Gates Racing Belt and OEM Water Pump: (Retail: 582.99) Custom Kelford 294 degree Cams: (Retail: 620.00) Power Enterprise Headgasket: (Retail: 264.99) OEM Mitsubishi Crank Position Sensor: (Retail: 109.15) MAP Ultimate Duty Headstuds: (Retail: 249.99) ITM Lifters: (Retail: 94.99) Assembly to Long Block: (Retail: 800.00) Degree top end into bottom end: (Retail: 300.00) I am sure there are several components I am forgetting/missing in this list but everything pictured will be included except the alternator! This engine is sold as used but has been freshened up and is ready to be dropped in! Total Retail Cost for this entire package would normally be: $14890.45 Buy it now and we will ship this engine out anywhere in the 48 contiguous states for 9999.00! |
http://i1283.photobucket.com/albums/...ps4a69d42f.jpg
Look at this engine! It's beautiful and runs like a champ! |
Long shot, but is this still available?
I'm so sorry. This has been discontinued
