Boost Taper - Why?
I believe it is just a feature of the ECU and how the waste gate actuator is configured. There is a little trick to make the turbo hold more boost by adjusting the waste gate actuator. you do this by taking it off the turbo and turning the "rod" about three times or so. I believe its clockwise. I know of a guy locally that is holding 20 or so pounds of boost by doing this little "trick".
Well, when something doesn't seem to fit linear logic, I will definitely raise my hand to ask questions.
In any case, having just given myself a crash course in turbo sizing via online resources, it seems the 16g is just walking too quickly out of its efficiency range at that boost level and rpm.
Here's another nice website that discusses turbo sizing for a 2.0L engine: http://wolfkatz.com/DreamweaverDocs/...on%20Small.pdf
Looks like if you want more boost efficiency in those rpm ranges, you'll need to be 'livin large' = $$$
Forgive me if I am wrong but from what I have read, it has to do with the efficiency of the turbo. Stepping to 22psi from 19psi doesn't always produce a corresponding increase in WHP but it definately increases the stress on the engine.
I guess this is one of the areas skilled tuning comes in -- balancing efficiency, power and reliability.
According to my chart, 22psi boost at 7000rpm requires ~0.28-0.29 kg/sec. This falls outside the turbo's efficiency zone (e.g. <68%), and it gets worse as the rpms increase.
Now I understand.
Now I understand.
Originally Posted by Jorge T
But even on this std rotation 16g 20 psi is in the 68% island
yep Ted B any turbo will reach its point of deminishing returns where it is making pressure by heating air. The net is more pressure but fewer molecules of 02. I believe it's boyle's law if my ole memory about physics is still with me.
oh well time to start saving up
