Help Shiv, need info!!!
Old Nov 19, 2004 | 10:40 AM
silverEVO8's Avatar
Question Help Shiv, need info!!!
OK, I want to remove the mods of my car. The MR deal is on again
Anyway, I want to replace the 680cc injectors and fuel rail in the car with the stock fule rail & injectors. My question is, can I safely do that with the Xflash? Or does the Xflash scale the ECU for the larger injectors?
Thanks,
Manuel
I've got until Wed to deliver my car to the dealer and get my new MR
Old Nov 19, 2004 | 10:44 AM
David@Vishnu's Avatar
Thanks,
Manuel
your injectors were scaled
Old Nov 19, 2004 | 10:48 AM
silverEVO8's Avatar
Thanks for the info David, what is the danger of running the stock injectors with the scaled map? will it be OK until it goes in boost? I just need it to get to the dealer. They can reflash it back to stock anyway. I just need to make sure it does not granade getting to the dealer......
Old Nov 19, 2004 | 10:50 AM
How far? it is an unsafe condition for sure see if Andrew can add a bunch of fuel with the xede
Old Nov 19, 2004 | 10:54 AM
silverEVO8's Avatar
Well, the XEDE would have to come out too. Would it be OK to have the dealer reflash the ECU before changing the injectors? That's a possibility.... Otherwise it would be a 100 mile drive with the wrong injectors....
Old Nov 19, 2004 | 10:55 AM
Better than the other way around
Old Nov 19, 2004 | 10:57 AM
silverEVO8's Avatar
Thanks, I'll ask the dealer to reflash the ECU for the P0300 problem
Old Nov 19, 2004 | 12:55 PM
Noize's Avatar
EvoM Administrator
But will that overwrite the scaling? Send it to Vishnu; you have the Miata. They can turn it around the same day.
Old Nov 19, 2004 | 01:00 PM
silverEVO8's Avatar
I don't know about that. Maybe I should send it to Vishnu. BTW Seth, I called your number, did you get my message?
Old Nov 19, 2004 | 01:02 PM
Noize's Avatar
EvoM Administrator
Not yet. I saw a 404 number hit my caller ID, but I've been buried at my desk today. I'll call you tonight when I leave the office.
Old Nov 19, 2004 | 01:15 PM
silverEVO8's Avatar
Cool, thanks!
