Swapping ECU's
Swapping ECU's
Is it possible to use an ECU from someone else's car? I have an '03 and someone on this forum is selling an ECU from an '03. I am seriously considering it so I don't have to have downtime when I send my ECU in to for the XEDEFlash on my Stage 1+. Anyone have experience with this? I did a quick search and didn't come up with anything real concrete.
Thanks
Thanks
Originally Posted by jfh
My understanding is that you will have to take it to a dealership to get the security code flashed to work with your car.
i dont quite remember but yeah the only problem you may have may be with the immobilizer i asked the same question, i think vishnu can program your second ecu immobilizer or something like that thats what he responded to me ask vishnu and explain he can probably take care of you
I have asked the same question, i was told that each ecu has the vin# or identifier in the ecu, so it can only be used for YOUR car. they are not interchangeable. Maybe you have to re enter or change the security codes. but you cant just swap ecus without doing something electronically to them.
well this is from personal experience. i had the factory reflash from mitsubishi, not knowing it would no longer allow me to boost as high or rev as high thanks to the xede flash i had burned onto the ecu. anyways they told me i needed a new ecu in order to put the xede flash back onto it. i also have an 03 evolution. when i ordered my ecu from the dealer they said they needed my vin# because for that year alone there are 8 different ecus. so there is a chance it might not work.
who knows maybe. what sucks though is i couldnt find any ecus in the forums so i had to buy onebrand new. it cost 900! anyways i got it and didnt even think about installing it at first to see if it worked. anyways i sent it to calvin at vishnu and he put the xedeflash back on it for me since my last one had it done. got it back, installed it and my car wouldnt start. i double checked the connections and it still didnt start. i installed my old one and it did start. tried to install new one again and it still didnt start. now mitsubishi is doing and exchange with me for another one.
Delaership is full of ****.... There is only 1 ECU for the EVO8 You can swap ECUs, BUT you have to get the keys (immobilizer) reprogrammed to your car, just like TurboDan said earlier. Unless you buy another Immobilizer ECU. The immobilizer p/n is MR587939.
Originally Posted by gvr4v
That
That p/n is MN132874. Andrew is correct about needing the ECU# for warranty, but if you're paying for it, then they are lying.
and get reimbursed for their cost plus labor. Makes for good profit. Anyway, that's what I would figure.
