Help with Trouble Codes
hey guys,
i just got my first p0300 today after almost 20k Xede driven miles. i also noticed a stored code of P2263 Turbo/Super Charger Boost System Performance. that one isn't very old since i just got inspected 3 weeks ago. the p2263 didn't pop the SES light. could the stock boost solenoid be to blame for the P2263? help is appreciated.
thanks
vincent
ps i'm running a gt3076r.
thanks
vincent
Hope this helps,
DTC P2263: INTAKE CHARGE SYSTEM MALFUNCTION
TECHNICAL DESCRIPTION
The ECM indicates or monitors a minimum prescribed value of volumetric efficiency within the boost operation range, which is determined by the signals from the throttle position sensor and the engine speed.
DTC SET CONDITIONS
Check Conditions
Intake air temperature sensor, barometric pressure sensor, volume airflow sensor, and throttle position sensor are normal.
Engine speed is between 3,000 and 5,000 r/min .
Throttle position sensor output voltage is higher than 2 volts .
Judgement Criteria
Volumetric efficiency is lower than 80 percent.
TROUBLESHOOTING HINTS (THE MOST LIKELY CAUSES FOR THIS CODE TO BE SET ARE
Turbocharger wastegate actuator failed.
Turbocharger Wastegate Regulating Valve failed.
Charging pressure control system failed.
Intake charge pressure leak.
ECM failed.
DTC SET CONDITIONS
Check Conditions
Judgement Criteria
ECM failed.
