took off Bov
Originally Posted by dafarmer69
no.. this is as bad as the guy who wanted too know if he needed a flash cause he was changing his trans.. a bov does not add performance.. so it doesnt affect a tune..
as you know VTA losses HP. I know Shiv kinda worked around it so I didn't lose that much hp during shifts. Just a question...
I changed out my stock BOV to a JDM MR BOV. In 3rd gear I am now hitting 23psi spike holding 22psi to about 6000rpm then to 18 by 7500rpm. When in 4th gear I hit 24-25psi spike.
I have a Defi D boost gauge and it matched my DD dyno session exactly for psi. Even though everyone thinks you are a tard when you ask if you need a reflash with a BOV, I am a little concerned. What is going to happen when it's 40 degrees out and not 90 degrees.
I have a Defi D boost gauge and it matched my DD dyno session exactly for psi. Even though everyone thinks you are a tard when you ask if you need a reflash with a BOV, I am a little concerned. What is going to happen when it's 40 degrees out and not 90 degrees.Trending Topics
Originally Posted by Greg K
turn the MBC down about 2 psi.
okay, since I took off blitz bov and put the stocker one back on, people say that stock one doesn't hold boost as well. What you guys think and recommend of a different bov
l8r)
