New Feature Request
Old Jul 12, 2005 | 11:48 AM
SuperHatch's Avatar
Originally Posted by Jeff_Jeske
Simple fuel cut for studderbox.
This'd make a SMART Xede into a Genius Xede....
Old Jul 12, 2005 | 11:53 AM
Jeff_Jeske's Avatar
More.....via DSMLink you could configure the studderbox to activate at above X% throttle and work until X speed was reached. NLTS was also similar.....requiring about 30% throttle to activate the feature and of course it knew what your speed was as well.
Works something like this:
Rev limit always applies. If the speed is below Launch Spd, the Launch rpm limit applies. Above that speed, the Shift limit applies if enabled, the clutch switch is active and the throttle position is high enough.
The only ....slight.... set back is that the NLTS switch on the DSM was using the UPPER clutch cut switch that came with the cruise control. I'm sure you could run the above algorithm using the lower switch instead.
BOTTOM LINE YOU CAN LEARN ALL ABOUT IT (with pics0 WITH THE USER MANUAL: http://www.dsmlink.com/DSMLinkV2.5%2...7s%20Guide.pdf
Old Jul 17, 2005 | 10:32 AM
Jeff_Jeske's Avatar
Bump....
Old Jul 17, 2005 | 10:37 AM
KillaSweep's Avatar
looking at Xmap that sounds pretty similar to the launch control options they have....but as we all know these features are not activated yet.....bummer!
