2Step and Rev limit help
if i save my shiv tuned map, and post it here can someone change my 2 step from 5k up higher, and change my rev limiter?
just want to launch higher, and im bouncing off 4th gear rev limiter before crossing the 1/4 line with my 6 speed, so i could like to get 2-3 more MPH out of 4th gear to help my times.
have a track day may 12th would like to get it changed before then.
thanks!
thanks!
Hey the launch control you can do it your self just take the launch control template and copy and paste your map in to that, for the rev limiter you would have to send the ECU to Vishnu so they can raise it for you, it is not possible with the XEDE.
Originally Posted by EvoRecordSetter
oh crap. so theres no way to change rev limiter?
how is it done then?
thanks for the post.
Well there is.. if you have had the limit raised already. My xede flashed ecu goes all the way to 8k. But since installing the 280s i use the launch control map to always limit me at 7600.
Hey do you already have the launch control on your map? If so than you just have to open the map with the Xmap and change the settings for launch control if you need help how too do it shoot me a pm.
