cam gear cover doesnt fit??
Old Feb 25, 2004 | 04:40 PM
alex_alex's Avatar
Does anyone else have the problem where after installing the Vishnu Cam Gears, the gear cover wouldn't fit anymore?
Well, i should say, it DOES fit, but the gears rub on the plastic.
Old Feb 25, 2004 | 04:44 PM
n00dle's Avatar
With the Vishnu cam gears you may need to take a dremel and grind down the nubs protruding out that slightly interfere with the new gears.
The pic shows the cover unmodified, but what you need to grind down.
Old Feb 25, 2004 | 04:46 PM
MP5's Avatar
MP5
In Timeout
Right you have to grind off the concentric circles (specifically the two outside circles)
Old Feb 25, 2004 | 04:50 PM
MP5's Avatar
MP5
In Timeout
Im destructive so I shaved it all off But this is what you NEED to do
Old Feb 25, 2004 | 04:55 PM
grasshopper's Avatar
i did that ,it work's great
Old Feb 25, 2004 | 04:59 PM
n00dle's Avatar
awe heck just shave it all off.
Old Feb 26, 2004 | 12:01 AM
alex_alex's Avatar
ok just making sure. I had Road Race do that for me.
Old Feb 26, 2004 | 06:23 AM
DEL TURBO's Avatar
Dremel off some of the inside in the upper corners. It can also rub there. I'd go about 2" on either side of the upper bolt holes.
Old Feb 26, 2004 | 06:31 AM
Smogrunner's Avatar
Finally, use a knife or other sharp object (like MP5's wit, for example) to dislodge the loose, ground down plastic that doesn't fall off. Otherwise it will come loose and gum up on the inside edges of your gears. Not vital but a good practice nonetheless.
