1++ what's recommeded next for a reassonable price
Hey all,
I signed up to get tuned by Shiv in March and since it is EXPENSIVE, I would like to make it worth while and of course add more parts :) But what? After a month with the 10.5 hotside, I find it added a lot of bottom/mid range and think it is a gread modification. I also found that (-2,-2) is the best setting for my car and feel it pulls pretty hard now. I do need more and would like the pull to remain constant to at least 7000 rpm and maybe scare me a little. I was thinking about a cat delete pipe and a lower IC pipe and am wondering about the alcohol kit as it would probably pull the most up top. My long term goal is of course to go with a stage 3, but I am pretty short on cash now. Your suggestions would help and I would welcome Shiv or David to assist in this matter. Sigfrid |
WIK will not help you much as you are not going to be boosting over 22 (turbo limit). Lower IC pipe will not give much HP (cant see more than 1 may 2 if you ar lucky). Of course the cat delete is the way to go as it will free load of power on top end and low end. I really cant see much to do after this beside replacing that turbo because it wont support more power. Stick with what you have until you save money ;)
It's turbo time. Purchase a performance clutch and injector upgrades if you have not done so already and just keep saving until you are financially ready to proceed.
| All times are GMT -7. The time now is 01:03 AM. |
