Maps don't match?
Well I finally got around to getting a USB to serial cable and connected to the Xede. The first thing I tried to do was download the existing (SMART) maps from Shiv's tuning in September so I could make a backup. Seems simple enough, I select "Download from Xede" and watch the progress bar fill up. Then, after the maps are loaded I get an error message saying that the current maps and the ones on the Xede don't match. Er, didn't I just download them? Anyway, I tried a few more times always with the same result.
Oh, if it helps, I'm using the Xmap software from vishnu's site which I believe is dated Aug 2005, while the Xede says its firmware is dated July 2005. What do I need to do now? I just want to make a good backup copy of the maps before I go and mess with them. |
Hmm. That's odd. When you do the 'download maps from Xede'. The resulting match should exactly match the one currently loaded. Maybe you should call shiv and see if he has a backup of that map. If he does, I bet it will match the one you just downloaded.
Oh. I have an idea. New thread time. d |
Mine does the same thing, must be that when you download map it defaults the file name to DEFAULT.XM3 and xede thinks files are different, I just hit ignore.
mine does the same dont worry!
Perfectly normal. Known bug :)
| All times are GMT -7. The time now is 05:44 AM. |
