Any idea Vishnu guru's
I have a question I hope maybe someone could answer.. To double check on the turbo itself, Does anyone know the spec's (size wise) on Vishnu's GT3037 turbos?
Below is what I got from Full-Race on the turbo specs. Compressor Specifications: -56 trim GT37 series compressor wheel with a max flow rate of 53 lb/min -0.60 AR ported shroud compressor housing Turbine Specifications: -84 trim GT series turbine wheel -0.63 T25 turbine housing -Steel ball bearing center section. |
| All times are GMT -7. The time now is 06:04 PM. |
