-   Vishnu Performance - California (https://www.evolutionm.net/forums/vishnu-performance-california-85/)
-   -   Disconnected battery. Now won't idle. (https://www.evolutionm.net/forums/vishnu-performance-california/86980-disconnected-battery-now-wont-idle.html)
DEL TURBO Jun 29, 2004 06:03 AM
While working on my car yesterday, I had disconnected the negative battery cable. Now the car won't idle. It also seems to be running poorly (missing). Is it possible that my XEDE did not initialize? Everything was great before disconnecting the negative terminal. Should I disconnect the positive side? :confused:
Noize Jun 29, 2004 06:30 AM
I've DC'd my battery lots of times without issue, so I don't think that's it. What else were you doing to the car when working on it?
bahamut Jun 29, 2004 06:54 AM
After DC-ing the battery, it takes some time for the car to relearn its ECU setting. It can take about 15 mins of driving or up to 3 days worth.
Noize Jun 29, 2004 07:01 AM
That's not true with an XEDE. On the dyno, it took exactly 1 run and less than a minute. There is no way it would make the car run like total crap like Del Turbo is describing. I've DC'd my battery loads of times. The problem is something else.
Dyno4mance Jun 29, 2004 10:01 AM
What were you working on DEL TURBO?
jj_008 Jun 29, 2004 10:07 AM
Even with XEDE disconnected or off the car should idle.
DEL TURBO Jun 29, 2004 10:35 AM
I had a new PE timing belt installed at Turbotrix. The car was running fine. It was about a 2 hour drive home in heavy traffic. At some point, it popped a CEL. When I got home, I removed the belt cover to check it out. I also unhooked the negative battery cable to see if it would clear the CEL. The CEL went away, but the idle is now dropping to 500 or lower when I let off the gas. The car keeps stalling. The car ran great until I disconnected the battery.
Why does the odometer and clock reset when you removed the negative connection, but it doesn't clear the radio settings? I think the radio will only reset when you remove the positive cable.
Noize Jun 29, 2004 10:38 AM
Think you jumped a tooth or two?
DEL TURBO Jun 29, 2004 10:54 AM
I don't think so. It was running fine up to the time I pulled into the driveway. After I disconnected the battery, it kept stalling. I'm going to check the cam gear position when I get home.
dpardo Jun 29, 2004 11:03 AM
Could it be an intercooler hose that's loose?
I've had mine come off a couple of times and that causes the car to stall.
Maybe it hasn't come completely off but is very loose?
BJai02 Jun 29, 2004 11:44 AM
Check all your hoses, including intake pipes (especially those hoses connected to your BOV), etc. You might have accidentally loosen a hose or two when you take off your timing belt cover... hope you find the cause soon.
TurbotrixRacing Jun 29, 2004 01:19 PM
Try disconnecting the battery ..and touch the brake .. when the terminal is off..
mark
Turbotrix
MalibuJack Jun 29, 2004 02:06 PM
Check your vacuum lines, it sounds like you might have disconnected one when you "examined" a few things.. I had knocked off the DV line once when I was working on my boost gauge and the car would barely idle, or just stall altogether..
Dyno4mance Jun 29, 2004 04:44 PM
Check your cam timing...it is possible that you have jumped a tooth or two on your belt... we have seen a vehicle run correctly for a time and then jump teeth if the tensioner is not adjusted correctly... the adjustment is very specific on the Evo tensioner...
The oil pump also needs timing when installing a new cam belt...check that they did this when installing the belt....this procedure requires the exhaust downpipe to be removed to access a plug in the front of the motor...a right PITA
When a CEL is thrown it is always a good idea to read the code and not just reset it as they are not always the codes we assume they are
My 2c
Andrew
Dyno4mance
TurbotrixRacing Jun 29, 2004 04:49 PM
My 2c
Andrew
Dyno4mance
We are not new to timing motors. .. The tensioner pulley is not losened . I used a rod to push in the tensioner.. Thank you for the schooling on how to time a motor but i think i got it covered ..
Mark
turbotrix racing
