Vivid Racing - Arizona With the best JDM selection of parts for your EVO and a great experience for your EVO upgrading, Vivid Racing is here to answer your questions and needs. [Visit Site]
Some EVO8 Stuff INSTOCK or on the way!!!
Old Mar 20, 2003 | 01:21 PM
Vivid Racing's Avatar
Here is a list of some EVO 8 products we have here or on the way from Japan. Instock items you can pay and have shipped asap. Incoming items you can put 50% down or pay in full to secure your products!
INSTOCK
Speedline GT-1 White Racing wheel - 18x8 35mm 5x114 18lbs each. Retail is $225 each. EVO Forum Users price - $185 each
PWR Alloy Radiator. Keep car temps low with this Aluminum radiator. Direct fit, fans fit the same as stock, no mods necessary. Drop in and takes 30 minutes. - $429
JIC Lower Arm Brace - Enhance your cars handling and rigidity with this lower arm brace. Bolts on in factory position. Available in white. - $95
JIC FLTA2 Coilovers - The FLT-A2 features a light weight, 15 way adjustable monotube damper that ensures high strength and fade free performance. The ride height is adjustable separate from the spring perch giving you maximum suspension travel at any setting. This also allows for proper corner weighting of the vehicle without effecting spring preload settings. Linear springs give laser precision steering response. All models include upper pillow ball mounts. MacPherson strut designs utilize front camber plates and feature high tensile steel brackets. Multilink suspension designs feature a CNC machined aluminum lower brackets. - $1795
JIC Header - JIC headers increase your exhaust flow to the turbo, decreasing turbo spool up time and increasing horsepower. - $650
JIC Titanium Cat Back Exhaust - Full Titanium piping and canister - Angled exit. As dynoed on the Vivid EVO ads an additional 13 horsepower to the wheels. - $1095
JIC Stainless Cat Back Exhaust - Same as titanium but full stainless steel. - $649
TEIN Flex Coilovers - As used on the Vivid EVO. Progressive Spring. 280 Front and 280 Rear spring rate. 16 way adj dampening, adj ride height, adj front pillow ball mounts, and rear standard pillow ball mounts. Great ride and improved handling. - $1550
Tein EDFC for flex...MUST HAVE - $349
Volk Wheels INSTOCK for EVO:
18x8.5 CE28N 33mm offset 5x114 (same size as on Vivid EVO)
Mercury Silver - $495
Gold with diamond lip - $525
Gunmetal with diamond lip - $525
18x8.5 SE37A 33mm offset 5x114
Bronze - $550
18x8 GTC 33mm offset 5x114
Silver - $495
18x8 GT7 33mm offset 5x114
Silver - $495
Gunmetal - $495
18x8.5 TE37 33mm offset 5x114
Bronze - $550
We have a ton of Turbo Timers, Gauges, Grounding Kits, Boost Controls, Injectors, and more electronics instock!
Items coming from Japan - Preorder
Monster radiator cap $49
HKS downpipe $499
Monster downpipe $499
Rigid Strut brace Front $315 Rear $215
Monster front strut bar $295
kakimoto cat delete pipe Straight type $225 with Silencer $275
Rigid Air Filter $65
Monster drop in air filter Same style of standard. $79
Monster Carbon Radiator Shroud $159
Monster Carbon Intake Duct $475
EVO7 Taillights Pair New - $390
We also have some other products coming like Ralliart IC piping, Samco silicon hoses and more!
Call us!!!
480-966-3040
Old Mar 20, 2003 | 05:38 PM
Celm's Avatar
Hey Vivid,
would you recommend the JIC Headers for a EVO 7 ?or these parts are mostly intended for the US EVO?
Old Mar 20, 2003 | 05:44 PM
They fit the same on the 7 as they do the 8. The header will have a noticeable gain. We always recommend starting with the basics:
Exhaust
intercooler upgrade
boost control
header
fuel system
Give us a call to chat more!
Old Mar 20, 2003 | 06:00 PM
TearItUpSports's Avatar
For comparison, what is the weight of the stock wheels?
Maybe wheel and tire weight stock vs wheel and tire weight of your upgraded ones used on your demo car.
Old Mar 20, 2003 | 10:08 PM
Stocks are 17x8 with 235/45
My SE37 are 18x8.5 and have 245/40
So I would guess with tires the SE37 about the same as my TE37 on my WRX weighing 34lbs in total.
Stock should be about the same.
Old Mar 21, 2003 | 10:20 AM
ONIMUSHA's Avatar
Do you guys do installs as well?? If so, is your garage staffed with trustworthy and knowledgeable technicians??
Also, where in AZ are you located??
I only ask because I live in Vegas and there isn't a single trustworthy import tuner garage in town (esp. for an EVO).
Thanks,
Oni'
Old Mar 21, 2003 | 11:04 AM
ONIMUSHA - Thanks for yoiur post. We do small installs here but leave the big work up to the folks at Dyno Comp near us. They have the facilities for bigger projects. We can schedule you time, just give us a call.
Old Mar 21, 2003 | 08:50 PM
Sano's Avatar
Are all the parts you are getting Evo 8 specific or were they made for the 7 and your just carrying them over. If not what parts do you have that have been created just for the evo8.
Old Mar 24, 2003 | 10:01 AM
Most of the parts from the EVO 7 and 8 are the same. Suspension, engine, interior, wheels, and some exhaust components are THE SAME!
Old Mar 25, 2003 | 09:43 PM
RedEvolution's Avatar
Can the EVO 7 tails be put on an EVO 8? I hate altezzas
Old Mar 26, 2003 | 10:00 AM
They sure can!!! We have 15 sets coming and taking preorders now!
$390 for the pair. Call to reserve yours!
Old Mar 26, 2003 | 09:30 PM
Darwin8's Avatar
Is there an intercooler upgrade for the EVO 8 yet?
Old Mar 27, 2003 | 10:31 AM
Yes there are several and they will be on the site today. However the difference is minimal and I recommend the piping kits are going a different route to make power.
Thanks
Old Mar 27, 2003 | 11:46 AM
DB8GSR's Avatar
Holy chit.. you guys rock!
Also.. are the Evo 7 tails priced @ $390 with shipping included?
Old Mar 27, 2003 | 11:49 AM
Shipping is extra. We have sets available and you can order online or call us! Wheel section going up right now!
