moving forward with ethanol injection
Old Jul 26, 2007 | 07:14 PM
94AWDcoupe's Avatar
Got my rail built today. I used an old dsm fuel rail and chopped it down. Welded some brackets on so it is easily removable from pipe to pipe. Can be used on steel or aluminum 2.5 pipe. Decided to use regulator, makes more sense than not using one.
Old Jul 26, 2007 | 07:15 PM
Paul Nelson's Avatar
Very nice are you going with E98? or E85?
Old Jul 26, 2007 | 07:31 PM
94AWDcoupe's Avatar
I found e99 locally for 2.45 a gallon. Gonna try that.
Old Jul 26, 2007 | 07:49 PM
aqmist's Avatar
Thats pretty damn cool, I like that a lot. Do you have a part number on the HKS controller, I was using the SMT-6 as a 5th injector controller for my Aquamist HSV, Perfect Power referred to this type of setup as a "Turbo Fueler" and I'm interested in how HKS approached this.
Old Jul 26, 2007 | 08:02 PM
94AWDcoupe's Avatar
4204-ra005 is part number. Not sure they are still available. I found this one new on e-bay for 250$. The controller can control 1-4 injectors. Uses a 3 bar map. Has two curves to adjust injection. One map based, the other is rpm based. Should work really well. Greddy made an AIC as well. Technology that has been around along time. just finding a new use for it.
I am going to use a hobbs switch to turn on pump at 2psi. Then start injection around 5 psi. Gonna use dsm 450cc injectors or evo 560s. Both are cheap. this system will be as reliable as primary fuel system. No need for failsafe.
Old Aug 12, 2007 | 10:52 PM
darqnez's Avatar
this is very interesting, any progress since last post? cant wait to see how its installed completely
Old Aug 29, 2007 | 09:54 AM
TiburonRaven's Avatar
занятная конструкция) сколько манни?
Old Aug 30, 2007 | 02:00 PM
Ultimate CC's Avatar
good stuff, love the design...
94AWDcoupe
Jul 14, 2023 08:38 AM
94AWDcoupe
Sep 9, 2011 10:41 AM
94AWDcoupe
Sep 26, 2010 10:45 AM
94AWDcoupe
Sep 30, 2006 09:46 PM
94AWDcoupe
May 13, 2006 10:51 PM
