Adding external spray light for SMC controller??
Old Aug 5, 2007 | 11:48 AM
  #31
Kerr's Avatar
Fomer Vendor
Problem, what setting do I use on the multimeter? I tried a few but none resulted in anything near 4.5. It was like 1.
Old Aug 5, 2007 | 12:30 PM
  #32
HmanEVO's Avatar
You want to set the knob to Vdc. There will be two V's to select from. One will have wavy lines next to it(For AC) and the other will have straight lines(DC). You want the V with straight lines for DC voltage. You may have a range button also you'll have to hit a couple times. You can set it by connecting both leads to the battery and hit the range button until you can see ~12.XX Vdc showing up. That will help get the display in the correct range if you've never used it before.
Old Aug 5, 2007 | 01:18 PM
  #33
Kerr's Avatar
Fomer Vendor
Ok, it registered 5v. I got 3v leds, so the resistor should be 115 again. Now, I was looking at the resistors and there are different watt's, 1/4, 1/2, 1, etc., which do I need? And they only went 100 then 220, so I would need the 220?
And thanks for all your help, I am really lost with this stuff.
Old Aug 7, 2007 | 02:15 PM
  #34
Kerr's Avatar
Fomer Vendor
Bump for more help please.
Old Aug 7, 2007 | 08:25 PM
  #35
HmanEVO's Avatar
Sorry didn't get back to you sooner. You should be fine with a 1/4 watt. As far as what resistor to go with, you can try the 220 ohm. If the LED seems too dim then you may want to check around for a local electronics store that sells a wider range of components. They should have something closer to the 115 you need. And you may find that the 220 works just fine. It won't hurt experimenting as long as the resistor is > or = to what you need.
Old Aug 8, 2007 | 05:32 AM
  #36
Kerr's Avatar
Fomer Vendor
Thats cool, I can't really work on it during the week, I just want to make sure I have it right and I can just go in and get exactly what I need.
I will try another place for the resistors, see what I can find. Thanks again.
Old Aug 11, 2007 | 08:08 PM
  #37
Pure Playaer's Avatar
Hey bro could u plz send over those pics of where u mounted the SMC kit! I need some ideas on where to put mine lol
Old Aug 12, 2007 | 06:23 AM
  #38
Kerr's Avatar
Fomer Vendor
The controller or the tank? Because for the 8's the tank replaces the intercooler sprayer in the front bumper. You wouldn't be able to do that. For the controller I put it in the little cubby on the left, just drill a small hole (1/4" or so) for the wires. I hope that helps.
Old Aug 13, 2007 | 11:19 AM
  #39
O i meant the controller! Thanks so much for the pic
Thats where imma put mine
Old Aug 16, 2007 | 02:53 PM
  #40
Kerr's Avatar
Fomer Vendor
I got it done, here are some ca-ca pictures.
Off:
On:
Old Aug 18, 2007 | 02:02 PM
  #41
Kerr's Avatar
Fomer Vendor
Added a power light:
And I wanted to thank GTVEVO and HmanEVO for all you guys help. I wouldn't have been able to do it.
Old Aug 18, 2007 | 07:10 PM
  #42
GTVEVO's Avatar
Glad to see you was able to get this finished! Looks great!
Old Aug 20, 2007 | 09:43 AM
  #43
HmanEVO's Avatar
I somehow missed your update but good job. Glad you got it working.
