twin jets and leaking meth?
Old Apr 9, 2010 | 10:09 PM
tephra's Avatar
Hi Guys,
ok so with 1 jet the water surface tension holds the meth in the tube (tube from the FCM to the jet)
but with 2 jets is it possible for the meth to leak or drain out of the tube between the jets?
is this something to worry about?
Cheers
D.
Old Apr 9, 2010 | 10:20 PM
JHowerton@Aquamist's Avatar
Are you seeing it outside the tubing or are you saying some is evacuating the tubing into the piping more now than with one jet?
Old Apr 9, 2010 | 10:40 PM
tephra's Avatar
not outside the tubing...
I dont know if its leaking inside the IC piping, but my guess is it is...
but only a small amount, just whatever exists between the 2 jets... since one is raised above the other...
Old Apr 10, 2010 | 04:52 PM
Richard L's Avatar
If the hose can be lower than the jets, gravity shoud help to keep the liquid inside hose.
Old Apr 10, 2010 | 04:57 PM
tephra's Avatar
yeah thats what I am thinking, I will probably have to redo the second jet line to run it lower than the jet itself... minimise the drain...
Old Apr 10, 2010 | 08:15 PM
mt057's Avatar
Are you seeing any air bubbles in between the jet and the fcm? You might try taking the jets out of the IC pipe and see if they drip.
