Aquamist jet Question
Old Mar 24, 2011 | 05:42 PM
car_nut15's Avatar
So I bought an evo with an aquamist HFS1 kit installed. The other day I was removing my intercooler piping and broke one of the jets/nozzles. I want to replace it and found a site that carries the jets. The jets have a little colored band on them I guess to represent the flow/size. The one jet has a black band and the other jet has a clearish/white one. There is no clear replacement ones so I take it its meant to be white? The nozzles also have a number stamped on the face. The black nozzle has a 1 on it and the clear/white one has what looks to be a 9. I guess the clearish/white looking one would be white since aquamist lists the white one as being 0.9mm. The black one is listed as 1.0mm hence the 1 stamped on the face? Just wanted to make sure before I order!
Thanks
Tommy
Old Mar 24, 2011 | 06:23 PM
mt057's Avatar
That sounds correct to me. Here is a jetting calculation chart from Howerton Engineering...http://howertonengineering.com/tech-...ating-jetting/
Old Mar 24, 2011 | 06:43 PM
car_nut15's Avatar
Ok I tried to use the calculator and I figure im in the 800-1000cc range. The problem is I dont know what pressure My pump is running at. If it had a white and black nozzle in it im gonna stick with that. There doesnt seem to be a 'clear' size jet so im gonna say its white.
WeirdGuyXp
Nov 23, 2015 02:39 PM
mr evo7
Jul 4, 2014 06:26 PM
mt057
11
Apr 24, 2011 11:28 AM
Darkn3s
28
Jul 7, 2010 01:56 PM
Import Junky
16
Jun 28, 2008 04:45 PM
