Please help quick - I'm at the drag strip
So I'm at the drag strip right now and my first run of the day my Aquamist sprung a leak at a fitting. It's the push connect fitting into the flow sensor. The 4mm push connect with the oring and thread on the other side. It's leaking from the oring on the inside that seals against the 4mm hose. Is there anything I can do to fix or can I run to the hardware store for anything?
Hopefully the day isn't going to be a waste. Thanks for the help.
You need to go to a pneumatic shop and ask for metric 4mm hose to 1/8 BSP fitting. Which system do you have?
It may be possible to cut back 1/2" and re-insert.
Richard
Richard
http://www.howertonengineering.net/c...sion-Fittings/
Hi, i recently finish installing my hfs-5 and my dss3 V.10 won’t come up, I have only the water level come up but when I press the button won’t do nothing, any idea what could happened, looks like the dss3 is faulty
