HFS-3 Power wire problem
I've got a problem with the power wire.Every time i touch the wire at the controller the power switches off and on again.Could it be the wire itself or the actual plug?
I've unplugged it before and saw the connection looks fine but i don't understand why this is happening,and the problem is i don't know where to find a new plug/wire.
I think the problem is a connection problem between the wire and plug going into the controller.It's not making contact.
What should i do because it's really annoying when there's no water spraying and i pick up knock...?
My tuner and i tested the power supply and relay,so that all checks out.
Can you give me the serial number of the controller. It could be the pins are not latching properly so it backs out when inserted.
Richard
Richard
wizzbangca
Lancer How Tos / Installations
32
Sep 4, 2017 12:32 AM
anthonyrb98
Apr 17, 2012 05:32 PM
