Evo 9 meth help
Old Jan 27, 2018, 01:34 PM
meric's Avatar
Evo 9 meth help
Hey guys have a few questions reguarding using meth. I dont have e85 in my area so i have a meth kit imma going to run in my evo 9. My mods are ported polished exhaust manifold and intake manifold. Full TBE airfuel ratio meter ets upper and lower intercooler gonna get 70mm tb and plate for intake manifold. Ets cold air intake walbro fuel pump. Aem meth controller with low level sensor and sight. Imma alsor running a manual boost controller. Now from what i have read i will need bigger fuel injectors what would anyone recommend i was looking at 880s or 1000s as i was going to maybe upgrade my turbo to an fp green. With no turbo upgrade i was looking to hit 400 hp. What size jet should i run with this setup. I am using stock evo 9 cams any help would be great
Old Jan 27, 2018, 04:46 PM
mt057's Avatar
I ran two 1mm. A .8mm and .8 mm would be good. The more meth you run the less injector you will need. Just make sure your failsafe is set up properly. I like a lot of meth though and ran 100%.If running 50/50 you probably don't need as much.
Old Jan 30, 2018, 12:00 PM
meric's Avatar
ok guys looking to hook up fail safe so i dont blow my motor how is that wired in to the evo 9 ecu
Old Jan 31, 2018, 04:34 PM
meric's Avatar
so no ome has done this come on guys give out sime help with this
Old Jan 31, 2018, 04:48 PM
mt057's Avatar
Sorry man, I used aquamist
Old Jun 12, 2018, 07:23 AM
C6C6CH3vo's Avatar
The only way to know if you need more injector would be to log AFR vs idc, airflow, ipw.
For instance, I have been running stock injectors with methanol inj since 2006, eng is still stock with 160k miles. BBK full turbo was installed 2007. The only time it ran out of fuel was when too much water was used. The alcohol system does consist of 2 pumps and 3 nozzles
Old Sep 10, 2018, 06:30 PM
inin36's Avatar
im using aem methanol kit. size depending on your tuner
tscompusa
Jun 21, 2014 12:02 PM
blackonblackevo
Apr 24, 2008 09:07 AM
evilevo2006
20
Jul 2, 2007 01:41 PM
dp2580
21
Feb 28, 2007 01:10 PM
Lancematic
Sep 25, 2006 02:09 PM
Quick Reply: Evo 9 meth help
