Who's who and what and where...
********** Updated: 23rd February 2014 **********
It is a good time to do a complete listing of current water/alky injection manufacturers and their product. Specifications, capabilities and price range. It is a copy post from EVOM a few months ago and have proved to be useful to most potential WIA users. I will start and fill-in more manufacturers as more information is available: Activeautowerke Location: Active Autowerke Miami, Florida, USA. Capabilities: Adjustable manifold pressure activation Pump: Shurflo Electronic Controller option:: No details Chemical compatibility: Water, Alcohol Failsafe: not mentioned on site Price range: US$1200.00 Warranty: Not mentioned on site URL: http://activeautowerke.com/cooling/main.php EMAIL: aatuning@activeautowerke.com AEM Location: Hawthorne CA 90250 USA. Capabilities: Progressive delivery proportional to IDC/MAP sensor. Pump: Aquatec with by-pass USA Electronic Controller::Based on pump speed to vary pressure/ flow. Chemical compatibility: Water, methanol Failsafe: Turbine Flow sensor based as an option from US$277. Price range: US$422-450 Warranty: 1 year unconditional and 100% methanol URL: http://www.aemelectronics.com/water-...ction-kits-23/ EMAIL: emstech@aemelectronics.com AIS Location: No address published, believed to be USA. Capabilities: Progressive delivery proportional to manifold pressure and any 0-5V signal. Pump: Aquatec with by-pass USA Electronic Controller:: Based on pump speed to vary pressure/ flow. Chemical compatibility: Water, methanol Failsafe: No option on site. Price range: US$468.99-659.00 Warranty: 1 year unconditional and 100% methanol URL: http://www.alcoholinjectionsystems.com/index.html/ PHONE: 1-801-447-2559 Alkycontrol Location: Alkycontrol. USA. Capabilities: Progressive delivery proportional to MAP sensor. Inline filter, metal fittings, and stainless steel braided lines. Pump: Shurflo Electronic Controller::Based on PAC module controlling pump speed to vary pressure Chemical compatibility: Water, Alcohol Failsafe: Failsafe Bi-colored LED works of pressure sensing, inline filter, metal fittings, and stainless steel braided lines. Price range: from: US$425-495 Warranty: 1 year unconditional and 100% methanol URL: http://www.alkycontrol.com/ Online form or phone Aquamist Location: ERL Ltd, East Sussex, England. Capabilities: PWM inline valve and electronic controller Pump: 160psi by-pass Aquatec pump Chemical compatibility: Water, Methanol. 100% methanol. Failsafe: Turbine flow sensor- full time monitoring with in- dash gauge. boost drop and map switching output. Price range: US$550-850. Warranty: 12 months URL: www.aquamist-direct.com EMAIL: richard@aquamist.co.uk (sales enquiry), richard@aquamist.co.uk (technical) Aquastealth Location: Not specified, somewhere in USA. Capabilities: Static flow, Pressure switch activated inline solenoid. Pump: Shurflo Chemical compatibility: Water and Methanol. Failsafe: unspecified Price range: US$199.00 Warranty: Not mentioned on site URL: www.aquastealth.com EMAIL: sales@aquastealth.com Coolingmist Location: No shop address. believed to be USA based. Capabilities: Progressive, Static flow – single or dual stage Electronic Controller: Digital Programmable "progressive" style controller capable. Pump speed based. Pump: Aquatec USA Chemical compatibility: Water, 100% Methanol. Failsafe:: Pump current monitoring - no flow sensor option. Price range: US$270 to $899.95 Warranty: 1 Year Warranty URL: www.coolingmist.com EMAIL: coolingmist@comcast.net Devilsown Location: Oklahoma City, Ok USA. Capabilities: Static flow, PWM pump speed control option Electronic controller option: 0-5v (selectable scales 2 bar,3 bar,voltage) – pump speed based system. Pump: Custom Aquatec USA Chemical compatibility: Water, 100% Methanol safe (EPDM Seals) Failsafe: None. Price range: US$380-460 Warranty: One Year Limited www.alcohol-injection.com EMAIL: sales@.alcohol-injection.com (sales inquiry), support@alcohol-injection.com (technical) Hydramist by Element Tuning (Work with Hydra EMS only) Location: WA, USA. Capabilities: Full 3D hi-res mappable, inbuilt failsafe. Electronic controller: Element Hydra stand-alone EMS. Pump: Shurflo (150W), with 160psi internal by-pass Chemical compatibility: Water, Methanol, Ethanol, Iso-propyl Failsafe: DDS3 flow sensing system - auto map switching via DDS3 v7. Price range: US$799.00 not including Hydra EMS Warranty: Not yet specified EMAIL: phil@elementtuning.com URL: www.elementtuning.com RSR Location: RB Racing, California, USA. Capabilities: Static flow, Port injection Pump: Shurflo Chemical compatibility: Water, Methanol. Failsafe: water level switch Price range: US$745.00-795.00 Warranty: call URL: www.rbracing-rsr.com/waterinjection.html Snow Performance Location: Snow Performance, Colorado, USA. Capabilities: Static flow, solenoid Electronic controller option: Progressive pump speed controller +$129.00 Pump: Shurflo Chemical compatibility: Water, Methanol Failsafe: turbine flow sensor- boost bypass, map switch. Price range: US$604 - 803 (IDC/MAP/MAF vs Pump speed) Warranty: limited option by vendor URL: http://snowperformance.net EMAIL: sales@snowperformance.net This is by far the most comprehensive research I have done for a long time. I will continue to update. Adding more manufacturers. http://www.aquamist.co.uk/forum/compare-4.gif richard@aquamist.co.uk . . . |
Wow what a great idea, this has got to be stickied.
What about Buschur, AMS... |
Please send information,
I will update it - I believe SMC made some of them? Please confirm. I need all your help to compile the entire list. It may looked biased since I have put Aquamist on the top - unless I call ourselves Zquamist. Richard |
I have just visited AMS and Buschur website and none are listing water/alky injection kit.
I am only listing manufacturers and not product re-labelled resellers. Richard |
Aquamist is COOLER :D
Not off to a good start... TTP-Engineering does not sell Snow Performance kits. You did not request this information from us and your misinformation is slanderous. This thread should be deleted if the information cannot be kept factual. We are located in Orlando, FL which is no where near Calardo or Colorado.
Where is the Truth Squad when you need them? LOL TTP Engineering Location: Snow Perfprmance, Colardo, USA. Capabilities: Static flow, Progressive controller –sold separately(PWM pump) Pump: Shurflo Based Control option: pressure switch, TPS or MAP (0-5v selectable) Chemical compatibility: Water, Methanol Failsafe: Not mentioned Price range: US$399.00 Electronic Controller: not mentioned on site Warranty: not mentioned on site URL: http://www.ttp-engineering.com EMAIL: online form filling I will update the list as more information becomes available. Please post on this thread if you have found any incorrect information – use the above information at your own risk. Richard L |
hmmm......did you have some bad food for dinner? The nice dude is trying to summarize what is available out there...........and all i can see is the location is entered wrong...and you are all bent out of shape....slanderous? :rolleyes:
Originally Posted by TTP Engineering
Not off to a good start... TTP-Engineering does not sell Snow Performance kits. You did not request this information from us and your misinformation is slanderous. This thread should be deleted if the information cannot be kept factual. We are located in Orlando, FL which is no where near Colorado.
Where is the Truth Squad when you need them? |
Buschur uses SMC and AMS uses alkycontrol
had to dig this one out from a past post, barb fittings and vinyl hose.........any idea how it works?
http://www.aquatune.com/index.asp |
Richard L wrote:
I will update the list as more information becomes available. Please post on this thread if you have found any incorrect information – use the above information at your own risk. ----------------------- TTP Engineering: I don't understand your point. Why is it slanderous? Or vendor bashing? He ask for comments which you have given him. He made a mistake and I assume will fix it. If he doesn't, I'll remove it. Speedlimit... |
No wonder the English think we are jackasses. Richard L has been the most helpful person I know in the water injection arena going as far as sending me parts from England free of charge. This truth squad BS is getting out of hand, everytime something happens on this forum somebody brings up that bull*hit. Shame on you Tom(smogrunner) for starting this crap. Funny he knows better than to try to start something like this on SoCal Evo.
Originally Posted by Speedlimit
at least...this is more civilised......just PM Richard or write the correct info here and it will be corrected once he sees it :beer:
I am certain Snow Performance would not like our company name paired with their address and location. Likewise, we do not sell their products and do not want to be associated with them. Everything from the location to company to the pricing is incorrect.
How about AMS alcohol kit?and how about the fancy water system from Works?
| All times are GMT -7. The time now is 02:18 PM. |
