-   Water / Methanol Injection / Nitrous Oxide (https://www.evolutionm.net/forums/water-methanol-injection-nitrous-oxide-173/)
-   -   What's the resultant effects of nozzle location? (https://www.evolutionm.net/forums/water-methanol-injection-nitrous-oxide/185852-whats-resultant-effects-nozzle-location.html)
C6C6CH3vo Feb 22, 2006 10:31 AM
Can anyone share any info on the theory of nozzle location, the effects, and ideal location in respect to TB for most power (disregarding fit and integrety).
Assume it's on a typical setup - a system about to be installed on a 300whp evo using 80 - 100% methanol with say 375ml/min @ 60psi nozzles, planning to boost to 26 psi..
Like what does moving it closer or further away from TB result in or any other stuff?
Thanks
Saikou_kun Feb 22, 2006 07:11 PM
I am also interested in hearing various opinions from people who have experimented with nozzle location ! {thumbup}
SlowCar Feb 22, 2006 07:34 PM
60psi against ambient pressure (0 psig) = 375ml/min
60psi against 26 psig boost = ((60-26)/60)^0.5*375 = 282ml/min
You loose about ~25% of injection + atomization will suffer slightly. Why only go with 60psig pressure?
just wondering......
lexat20 Feb 22, 2006 07:36 PM
Thanks
+2
Evoryder Feb 22, 2006 07:40 PM
response is better closer to TB ...i've tried further away...temps are better with nozzle closer and angled to cover more cylinders. I run 100% tried running at 50/50 and car felt weaker...depends on tune.
my 2c
AlohaEvo Feb 22, 2006 11:29 PM
how do you angle for more cylinders?
Evoryder Feb 23, 2006 06:43 AM
with an L bracket/nozzle...vs just having the nozzle spray down ...it sprays past the TB covering more ....
Saikou_kun Feb 23, 2006 08:27 AM
I totally agree with you about spraying WITH the air flow for getting FULL and EVEN water dispersement.
EvilBlueEvo8 Feb 23, 2006 10:16 AM
thats an interesting idea but i think its already been done. not positive though
AlohaEvo Feb 23, 2006 11:37 AM
nice, might have to try and get that going before saturdays tune
Evoryder Feb 23, 2006 02:32 PM
its' definetly been done...
...ive seen it many times...i have my nozzle welded to a hard pipe b4 my TB ...so i'd have to buy a new nozzle. This can be done DIY from parts from a Home Depot/lowes...but having something preconstructed is good...oh and make sure its stainless steel...100% meth is corrossive if using that...like muah
C6C6CH3vo Feb 23, 2006 02:47 PM
Makes sense with closer to TB allowing vapor to go to a gas deeper into compustion.
About how close to TB are we talking about? With it closer the chances of equal distribution to each cyl decreases.
With a 160psi shurflo, exactly what psi sits at the nozzle at max pump setting, and full power?
moto17 Feb 23, 2006 05:18 PM
is it running progreessive or on/off?
C6C6CH3vo Feb 23, 2006 05:24 PM
Progressive
EngineRunup Feb 24, 2006 12:09 PM
On the cars I have installed it on that are similar to the Evo, I have found that as long as you use small nozzles (for better atomization) and a high pressure pump, the closer to the intake the better. The computer gives full timing advance without messing with your boost levels by seeing a false low temperature by the sensor being saturated with the water/meth. Don't get me wrong, the temps are lowered for the air charge, but the water is still cooler than the surrounding air, so as it hits the sensor, the temp readings are lower than they actually are.
