nice container
12L......hopefully will last awhile with ~800cc/min spray
looks like a lot of meth is going to be sprayed...nice...
i'm going to water down the methanol in hopes that the pump seals/diaphgram and all will "last" a bit longer
dual pumps...nozzle locations?
in the UICP, similar to my 1st project
https://www.evolutionm.net/forums/at...9&d=1134345023 this time, i will use 2, one firing forward to the TB, the other, counterflow, firing towards the intercooler |
I like..
these aquamist jets do a real good job at atomization, air should be nice and cold when it enters the motor
Originally Posted by SlowCar
(Post 3751535)
7 liters last me about 9 days at 675ml/min (100psi rated)
Cant see any pictures |
Originally Posted by C6C6CH3vo
(Post 3751575)
Cant see any pictures depends on how much lead is in your foot... |
Originally Posted by Evoryder
(Post 3751566)
u gonna do some logs...intake air temps before ...after what not? looks solid
Yeah, and if you can post some 3rd gear evoscan xml worksheets. The timer vs rpm is a good indicator of improving speed
i'll do it after the tune from jestr mid jan07
