-   Water / Methanol Injection / Nitrous Oxide (https://www.evolutionm.net/forums/water-methanol-injection-nitrous-oxide-173/)
-   -   Two HSV's with one Aquamist controller (https://www.evolutionm.net/forums/water-methanol-injection-nitrous-oxide/369883-two-hsvs-one-aquamist-controller.html)
megavar Sep 17, 2008 04:01 AM
Hello,
I am wondering if Richard (Aquamist) or someone else, can tell me whether the aquamist system in it's standard form (eg HFS 5) is capable of controlling two high speed valves in parallel?
If not, is there an efficient way of doing this?
cheers
Matt
Richard L Sep 18, 2008 12:52 AM
The FIA2 can drive two HSVs. But one HSV can flow more than enough for most applicactions.
megavar Sep 18, 2008 01:27 AM
Thankyou Richard,
the HSV's will be doing separate jobs, that is why I want two.
cheers,
Matt
dudical26 Sep 19, 2008 12:47 PM
They will run the same duty cycle though, how could you have them perform different jobs?
Please explain what you plan to do.
Unless you want to run different liquids through each, then I understand.
megavar Sep 23, 2008 10:58 PM
Dudical,
I have a spare ERL pump, injectors and HSV, so I was going to "upgrade" the intercooler sprays to run at a higher pressure using aquamist bits. I was hoping to get better atomisation than the standard unit.
I was thinking to activate it from the aquamist system, so it fires whenever the meth injection is running.
I will use the standard tank with a diluted meth/water mixture.
