Water Injection Calculator !
http://www.customperformancesolution...injectioncalc/
I'm running a single 1.0mm jet on my max'd out IX turbo and recently switched to E85 and saw some performance gains. This is a great tool to help you (and me) figure out what different jets should be used for optimal fuel percentages. I'm thinking of adding a 2nd jet (.5mm) to bring it over the top. |
hey thats really neat.
nice find |
Great find! :)
Hi guys,
If someone need an offline version, I made a replica in XLS format... Hope you will envoy it... Any improvement to original file will be appreciated! Version 1 is HERE Cheers! |
what is the fuel pressure at the fuel rail in an Evo VIII?
^^^ About 4 bar or a little less... expect 45 psi or more on the stock evo.
According to that calc one of my customers is running a 56.121% to fuel ratio with 2 x 1.0mms!! lol. That car is just plain fast!!! Evan Smith |
excellent find...
+1
I have question on Fuel pressure.
My fuel press at Idle is 2.8 bar and 4.5 bar at wot. Should I use 4.5 bar to calculate the injector size? |
1 Attachment(s)
i used the calculator and got some weird results...
Attachment 131199 It's saying i need about 1000cc of meth flow to have 20% MFR... seems a bit high, don't u think? |
Nope, that's about right :)
2x 1.0mm nozzles should get you close! These are ideal circumstances though, I think my setup only runs about 10-11% meth/water and I get great results. This is with a single 1.0mm jet. |
I have been reading thread after thread on selecting the correct Jet and restrictor size but don't seem to be getting it. I am running a IX turbo with stock injectors and will be setting up an HFS-6 system with a 50/50 mix. I am a little lost on how to know what my Injector/Fuel Rail pressure are and what the duty cycle will be? Can someone give me a how to determine jet and restrictor size for dummies?? Thanks for the help.
1 Attachment(s)
Most of those values you leave as-is. Stock injectors flow 560cc's and you have 4 of them. You need to log your car to see what your peak IDC is but if you have a walbro and all the mods listed in your sig, you're prolly running about 100% IDC peak pretty easily (not bad, I ran mine up to 127% :D ).
Anyways, decide how much meth/water you want to inject and set that percentage, or guess at what jets you want to run and work your way backwards. Last week I switched from a single 1.0mm jet and added a second jet. I was going to add a .8mm, but all I had was a .9mm so I just went with it. That adds up to 967cc/min based on the chart listed on that page. I'm using 2 injectors, so divide that in half for 483.5cc/min per injector target (average). With my setup and some rough numbers, that gives me about 22% of my fuel ratio being water/meth. Since I'm going for max power out of the setup, this is a good % to be at :D I attached a screenshot of the settings I used. Again, rough numbers but they work. https://www.evolutionm.net/forums/at...1&d=1246378813 |
Hrmm...
So I entered my stats: 560/95%/4/20%/160/25 and it reckons I need 2x 0.8 jets... But when I used the included chart from Aquamist it says I only need 1 jet?!? |
Tephra,
The chart on the HFS-6 is the maximum size jet without a tune. I don't think if will suit you. |
