hfs-6 won't stop spraying!
Hi there, I just installed the aquamist HFS-6 today in my evo 6, everything seems to check out, the FIDC light follows injector duty and the THRES light doesn't come on till i floor it however one huge problem is as soon as I turn it on it starts spraying? it's like the solenoid is constantly on?
hi richard, I fixed it, the problem was with the 2 grounds on the power plug, one said signal ground and the other normal ground. Signal ground I presumed mean sensor ground which I hooked up to on the ecu. turns out that was wrong, after putting that to standard ground pin 26 everything runs fine now :)
This kit is awesome, me and my mate, first time ever doing something like this took us 3 hours start to finish including making the makeshift water bottle :) |
| All times are GMT -7. The time now is 11:24 PM. |
