Aquamist's new HFS-3 for 2010, replacing the HFS-1
Aquamist’s “No-compromise” approach to the new HFS2/3: Tracks fuel flow faithfully across the entire driving cycle... -Power enhancement is consistent from cruise to full throttle at all RPM. The IDC System is particularly suitable for "Daily Driving" applications. Allows consistent AFR at all loads... The secret to smooth power delivery is "consistent" AFR’s at all loads, not just at peak power and torque. This import aspect is only offered by an IDC tracking system. A boost based system is only accurate at a given gear or RPM band - a 2D system cannot work well in a 3-D environment. System responds in a few thousandth of a second... A PWM-valve System can respond before an engine completes one cycle! The HFS-2/3 is a constant pressure system - flow is metered by a fast acting valve and not by varying the speed of the heavy rotating mass of a pump motor. Fast Acting Valve enables instant start and shut-off upon full/partial lifting of accelerator... Similar to the OE fuel injector, it can meter fuel delivery during an intake stroke thanks to the fast responsiveness of the low-inertia properties of the solenoid valve. Instant start and stop eliminates after-spray dribble completely. The HFS-2/3 uses the same technology. System performance is reliable and repeatable... A modern W/M delivery system is not about all-on and all-off performance, but more about its ability to vary flow within a few thousandth of a second. Even at constant road speed, your throttle is being modulated all the time. These are the little moments where a PWM-V system excels. No cost penalty over the PPS system... Not any more! Aquamist has managed to bring the price of this technology down to a level that everyone can afford. A street price from $499 (HFS-2) gives an entry into this proven technology. Plug and Play makes system installation a breeze... Installation time and wiring is time consuming especially if you are not electrically minded. The HFS-2/3, with its true "plug and play" construction, have all harnesses pre-wired with colour-coded plugs. Butt connectors and interconnection splicing are a thing of the past. Component quality is guaranteed to perform... Aquamist manufactures 90% of the components in house with strict quality control. When you purchase an aquamist product, you will enjoy full technical support and uncompromised quality. |
^^^ I have anxiously waiting for this day :D
These kits I imagine will be like the HFS-6 and not ready till summer 2010. Richard has so much work he has been doing and have yet to do!{thumbup} Patience to all. Evan Smith |
Awesome! Just to clarify, this is a single-stage kit, right? On/off, based on IDC or manifold pressure?
Originally Posted by scheides
(Post 7841248)
"The HFS-3 is very similar to the discontinued HFS-5, it mirrors the fuel flow at 1:1 ratio. You can change the ratio by sizing the water jet. However, it does have a gain trimmers to allow some form of rescaling to compensate for large fuel injectors that do not run up to 100%. It does not have the full set of adjustments offered by the HFS-6. The aim of this system is to update the HFS-1 to become a P&P progressive system at minimise cost to the end user. Utilising the PWM-valve setup to gain large dynamic flow range ." |
Originally Posted by esevo
(Post 7841179)
These kits I imagine will be like the HFS-6 and not ready till summer 2010. Richard has so much work he has been doing and have yet to do!{thumbup} Patience to all. Evan Smith Evan, Happy New Year! The HFS-3 is ready for shipping in Jan/Feb, starting with GB as before. I will post up GB details in January. It is our aim to make all of systems "plug and play", avoid the installation cost over-whelming the system cost. Each and every component is terminated with a plug, making connections in seconds rather minutes. Replacing suspect component is a breezy. |
(Post 7841248)
We have acquired/learnt knowledge over the last two years on how to make a fast actiing valve in house. With this knowledge, the cost of an inline valve has reduced considerably compared to buy from a third party. The HFS-3 component list is now satiisfactory and complete, ready to be incorpoated into a final product, at a cost comparable to a PPS system. We are now entering into a new market place, just hope people will appreciate the wide dynamic performance of a PWM-valve system. |
Originally Posted by Richard L
(Post 7841575)
No, it is a progressive system.
We have acquired/learnt knowledge over the last two years on how to make a fast actiing valve in house. With this knowledge, the cost of an inline valve has reduced considerably compared to buy from a third party. The HFS-3 component list is now satiisfactory and complete, ready to be incorpoated into a final product, at a cost comparable to a PPS system. We are now entering into a new market place, just hope people will appreciate the wide dynamic performance of a PWM-valve system. Does the -3 have the ability to shape overall flow? i.e. using oversized jets and then scale back peak flow to say 60% of what those jets are fully capable of. (this is a feature of the -6 IIRC). Also, can the trigger be a combination of both IDC and boost pressure, or must it be one or the other? |
(Post 7841759)
Holy crap that is insane! So would you mind educating us as to what the exact differences are between the -3 and the -6 kits? Both are progressive, both seem to have dynamic flow ranges, so the waters get a bit muddy.
Originally Posted by DBallz
(Post 7841765)
All the stuff he said scheides is a smart guy {thumbup}. I'm more concerned with the major difference between both kits cause I'm trying to figure which kit is more suited for me and the power I'm making
The HFS-3's adjustability is limited compared to the HFS-6.
It cannot (compared to the HFS-6): - offset against the initial F-IDC - the F-IDC threshold % = starting point of meth flow % - It doesn't have manifold pressure compensation - alter the failsafe reset period = pegged at 3 seconds - read "Direct Injection" pulses such as the 335i or Audi FSI pulses - control a MAC valve directly as with the HFS-6 It can: - put gain on the incoming F-IDC for purpose of having large fuel injectors running low DC. Previously, the HFS-5 has to be double pulsed. - You can run the system based on boost or IDC only. In single stage or progressive mode. - You can program it to be single point (HFS-1) or PWM-V mode (HFS-5). The HFS-6 has futher electronic signal processing to match the FAV's opening and closing period. That is all I can think of so far. |
Fantastic! the -3 sounds like an amazing setup! Can you explain how it supports boost trigger with progressive mode? Does the boost trigger have two trigger points, for min and max flow, like an SMC kit?
Furthermore, when triggering via IDC, does it work the same way? Low/high trigger point? |
You are always one step ahead of before update. Slow down!
OK, IDC or MPS after trigger, we just set the gain trimmer until the 95% IDC led (red led) lights up. At this point you know you have reached the full flow of the system. I doubt if anyone would want to use boost pressure as reference for meth injection as you have IDC. Still, it can be done on the HFS-3. For the same reason, any 0-5V signal can do the same thing. I will be posting the next update on the functions of the contoller. I have left enough space on top. |
(Post 7841567)
Evan,
Happy New Year! The HFS-3 is ready for shipping in Jan/Feb, starting with GB as before. I will post up GB details in January. It is our aim to make all of systems "plug and play", avoid the installation cost over-whelming the system cost. Each and every component is terminated with a plug, making connections in seconds rather minutes. Replacing suspect component is a breezy. Wow it must be because the HFS-6 was a good foundation for the new platforms that allowed such quick development time. {thumbup} The HFS-3 seems to be for those who want to set a system up them selfs and not worry about over adjusting. I.E EMS on a stock turbo evo... kinda over kill. The HFS-6 can also be fully implemented for other control aspects. Such as EGT, boost, IPW, even water oil temps if you want. lol Think of the HFS-3 as a HSF-5 but plug and play at the cost of the HFS-1. + extras{thumbup} Great Job Richard and ERL! Evan Smith |
