Welding & Fabrication Talk about anything related to welding & fabrication.
Fast_Freddie's crack at double pumper fab
Old Feb 2, 2011, 04:25 PM
Fast_Freddie's Avatar
Well running both pumps was a no go for me, and I am not pulling the DP back out of the car, so I went the hobbs switch route. Got everything I needed for install at NAPA for $35 (Military Discount FTW) and had it installed in about an hour. Went to Stage 6 as I needed an extra hand to adjust the switch point of the hobbs switch... set it to 9 psi. Now just have to find the time to retune the fuel map a bit at it runs rich now!
Fast_Freddie is offline
Old Feb 8, 2011, 07:06 PM
Retuned the fuel map while I was at AWD last weekend, car runs great, another 1000 miles on the motor and I will put some E85 back in for some real fun...
Old Dec 4, 2011, 09:49 PM
No updates?
scumbee is offline
Old Dec 5, 2011, 05:44 AM
What kind of updates would you like... I have had the DP set up in for almost a year and I have had no problems with fuel delivery...
I did turn the hobbs switch up to trigger at 15psi instead of 9psi...
Spec-Ops1 is offline
Old Dec 5, 2011, 08:22 AM
Steve220's Avatar
Looks good! How did you get around the venturi valve for feeding from one side of the tank to the other without its surround?
Steve220 is offline
Old Dec 7, 2011, 06:55 AM
The surround has nothing to do with the venturi effect, as the return flow goes through the restrictor inside the "y" it creates a siphon to pull fuel from the bladder tank into the main tank...
Old Dec 12, 2011, 02:28 AM
Do you have a part number on the hobb switch?
scumbee is offline
Old Dec 12, 2011, 03:57 PM
napa BK 7011577
Old Dec 12, 2011, 05:26 PM
Paul Walkin's Avatar
How does it perform in low fuel situations?
Paul Walkin is offline
Old Dec 12, 2011, 06:33 PM
I have run the fuel down to where I have had to put 13 gallons in the car and had no issues...
Old Jan 10, 2012, 03:50 PM
Jetfixrguy's Avatar
Nice work guys, thanks for sharing!! I am also in the middle of a custom DP set up, very similar in the design. I take it both pumps running at the same time couldn't be regulated low enough?
Jetfixrguy is offline
Old Jan 10, 2012, 09:27 PM
teribble's Avatar
Not without a aftermarket fuel pressure regulator.
teribble is offline
Old Jan 26, 2012, 09:24 AM
Jetfixrguy's Avatar
What size drill bit did you drill the syphon out with, and why do you have to do this? Can you get away by not drilling it out when running a stock fpr?
Old Feb 1, 2012, 06:31 AM
Yes you can run a stock siphon if you use the hobbs switch config...
Old Mar 2, 2012, 10:37 PM
What if you have an aftermarket regulator, will the return line be a restriction? All of those parts worked out well for you it looks like, awesome job. Id like to put one of these together and get rid of my dw ASAP.
420a-t is offline
Quick Reply: Fast_Freddie's crack at double pumper fab
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
