Las Vegas Evo's
Old Jul 10, 2005 | 06:05 AM
  #22966
joEvo8's Avatar
Originally Posted by evo81
i'm retired from the game.i'm out of it,and not returning.
anywayz, what was the final #'s?
i think corey did 330whp on 100 oct
gonzo did the same as corey i think,and i never found out how much jesse did.
if they all don't run 12's in 2 weeks,something is wrong.did they take pics of your car also IE?
Corey is only at 330whp.. at what boost? He has more Hardware on that car than Bob Villa.. he needs to lose the weight. I thought he would push higher than that.. 272/272, Fuel Pump, I/C, TB, MBC, Intake, what injectors does Corey have?
Old Jul 10, 2005 | 07:56 AM
  #22967
joEvo8's Avatar
Someone tell Manny to post a vid for my run w/ my engine failure!!!..hahaa..it went like.. vvrrooommm .. ttetettte... eerrttt.. vvvoommm.... BBbboooooff.. and then... (Audience)AAawwwww.... .. and then.. vvroommm.. ptp ptutptutt ptpttputtp utt.. pppsssshhhh....
Old Jul 10, 2005 | 10:58 AM
  #22968
gonzo's Avatar
Originally Posted by IE Evo
Many an Evo and SRT4 at TT today. Even saw the enemy STI. Gonzo u should of went another PSI. Stock turbo power levels is not going to blow the stock headstuds and blow the gasket. One more PSI and test pipe and Gonzo could of got 20 more whp. P ussy! LOL
Yeah I know. I could be making Jesse like powa.
So many bad *** EVO's there. That place is f ucking awesome. Jealous. Wish we had something like that here in vegas.
Old Jul 10, 2005 | 11:00 AM
  #22969
gonzo's Avatar
Its that gay *** dynoflash f ucking with his numbers.
Plus it was 95 degrees with 18% humidity when we hit the dyno.
Old Jul 10, 2005 | 11:11 AM
  #22970
joEvo8's Avatar
what was everyone's dyno #'s?..
Old Jul 10, 2005 | 11:19 AM
  #22971
gonzo's Avatar
I baselined at 296 with the buschur settings. My peak only went up to 303 at 21 psi but Alfred found some serious power hiding out. 35 in some parts and torque the same story. Alot of hp found under the curve.
At 100 oct at 24 psi I made 330 hp and 305 torque. I'm still using a cat so that should be good for 10 hp at least.
My runs were done at 95 degrees. So it was hot. Should be making more hp when it cools down some more.
Old Jul 10, 2005 | 11:21 AM
  #22972
IE Evo's Avatar
Not Jesse type numbers but a lil better. Get a test pipe and get 10-15 whp when u run the 22nd. Also Corey's car was no slouch in the Torque department but falls on its face before 7000 rpm. Funny thing was Gonzo's car flashless or Gonzoflashed made more baseline power than another flashed car. Typical Dflashed car torquey but falls on its face. Butt dynos are accurate and Corey's car proved it.LOL, Poor Corey! I know he is depressed and suicidal but Corey it could be worse. U could have my Evo,John's life, Gonzo's height, Sams mechanical skillz at putting in injectors, and V-Boys molestation and drug habits ;you feel better now?
Old Jul 10, 2005 | 11:24 AM
  #22973
IE Evo's Avatar
I baselined at 296 with the buschur settings. My peak only went up to 303 at 21 psi but Al found some serious power hiding out. 35 in some parts and torque the same story. Alot of hp found under the curve.
U mean Alfred. When u say Al people will think Dynoflashed. Also your baseline was 292 whp i believe and Alfred got u a lil more whp and 30 more up top and I thought your tq was a lil better also.
Old Jul 10, 2005 | 11:39 AM
  #22974
gonzo's Avatar
Old Jul 10, 2005 | 11:40 AM
  #22975
gonzo's Avatar
Corrected, Alfred it is.
Old Jul 10, 2005 | 11:48 AM
  #22976
IE Evo's Avatar
Went to the Speedway and was disappointed and depressed. Finally a fast STI at the Speedway running 12.5s at 110 mph or so and no evo can put that fool in check. Last night people were getting in multiple runs(low numbers of cars) and it cooled off. It was really depressing and I need to stay away from the Dragstrip or I will commit suicide or get an RS and waste all my savings making it Slorice II.
Old Jul 10, 2005 | 11:50 AM
  #22977
gonzo's Avatar
DO IT!
Old Jul 10, 2005 | 11:55 AM
  #22978
IE Evo's Avatar
DO IT!
Okay I will do as u say and Commit Suicide. BYE!
Old Jul 10, 2005 | 11:59 AM
  #22979
gonzo's Avatar
I mean buy the RS fool.
Old Jul 10, 2005 | 12:02 PM
  #22980
evo81's Avatar
i think he meant the subie rs
