spark plug gap
When running the p2 with other mods( intake, turbo back, upgraded FMIC and upper IC) what should I gap my iridium NKG plugs that I just bought. They are one step colder too. ANybody? Works , I doubt your out there, but if you are please respond as you dont respond to my e-mails :(
w2pac12345: call them. leave a message. they will get back to you.
It's just that it's a little crazier around there since DavidV left ... its just the people that actually do the cool work around there so it just takes them a little longer to get back to people. -S ... |
I think .024 - .025 is right about where it should be. That range also helps eliminate misfire codes.
JC |
TTT
For those of us with the P2, any reccommendation on what type of new plugs to get? Asking for a couple reasons: 1) How long should the stock plugs last? 2) P0300 misfire; some are replacing plugs and getting rid of it! 3) Some claim different plugs are needed when running higher boost that stock. |
WORKS recommends the OEM plug gapped to factory specs: .028-.031 You shouldn't need to go a range colder with the P2 boost settings.
In my own EVO, I use BGK BPR7ES gapped at .028 (I've used these plugs for years in my previous vehicles without issue). |
so how often should we change our spark plugs? how many miles? would you guys also change your spark plug wires everytime you change the spark plugs?
jfe |
jfe |
