XForce Axle-Back Exhaust Systems for Mitsubishi Lancer CJ 2007-11
XFORCE is one of Australia’s top exhaust system manufacturers and now they’re bringing their products – including their famous VAREX™ Mufflers – stateside.
XFORCE focuses strongly on research and development which ensures that our diverse range of exhaust products are of powerful engineering precision, stylish and practically designed to maximize performance and most importantly, technically. Our focus on innovation and extensive quality control enables us to provide you with outstanding performance values when it comes to your exhaust. XFORCE is heavily involved in continuous research and development that combines powerfully with their manufacturing advantage in exhaust production and automotive engineering. Their exhaust systems are specially designed and dyno tested by their state-of-the-art Dynapack Evolution 3000 chassis dynamometer machine, for proven maximum performance in the R & D centre in Australia.
WHAT ARE VAREX™ MUFFLERS?
VAREX™ mufflers combine both the design technology of the stock muffler and the performance muffler into one single compact unit. A sophisticated butterfly valve mechanism is implemented to redirect the exhaust gas flow and vary be-tween the two. For higher sound level, the exhaust flows are directed through the opening path and produces maximum power with a robust sound level (or the “sports car note”) and near-zero resistance.
• Easy Installation, no hard-wiring required (in-car 12v socket included) for plug and play functionality
• Durable construction with water resistant plugs
• Dual mufflers control harness available
Stylish remote key pad
Street Mode: Setting your Varex™ muffler in ‘Street mode’ enables lower sound levels and maximum discretion, as exhaust gases are directed through a chambered path as would a ‘stock’ muffler
Race Mode: For greater power output and sound level, exhaust gases are directed through the opening path and produce maximum power with a robust sound level (or the ‘sports car’ note) and near-zero resistance
In between: As the angle of the valve is infinitely adjustable, it can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
For more info about Varex mufflers go to http://www.xforceusa.com/products/varex-mufflers
AXLE-BACK SYSTEM
If you want better sound and performance from your car, the axle system will deliver it in droves at a very affordable price.
Suits: MITSUBISHI Lancer CJ 2007-11
Part No.: ES-ML03-R
RRP: Contact your local XForce stockist HERE.
Product Type: Axle-Back System
STAINLESS STEEL 2.5" AXLE-BACK EXHAUST SYSTEM WITH SINGLE SIDE OUTLETS
For a premium finish adding a bit more bling to your ride to go with the extra sound and performance.
Part No.: ES-ML07-R
RRP: $229.00
STAINLESS STEEL 2.5" AXLE-BACK EXHAUST SYSTEM WITH SINGLE SIDE OUTLET WITH VAREX MUFFLER
The VAREX™ Muffler gives you the best of both worlds. Whether you want to unleash full noise or keep discreet, the remote controlled mufflers allows you to choose.
Part No.: ES-ML07-RVMK
DUAL REAR VAREX MUFFLERS
Add an extra VAREX™ Muffler for air-flow which leads to the ultimate in performance and sound from your exhaust system.
Part No.: ES-FM05-RVMK
RRP: $849.00
WHERE TO BUY: http://www.xforceusa.com/where-to-buy
For more information on the full range for the Mitsubishi Lancer CJ 2007-11 or individual parts visit: www.xforceusa.com/bolt-on-systems-for/mitsubishi-lancer-cj-2007-to-11/cid-1063040110
XForce USA
XForce-USA
Jun 8, 2016 03:22 PM
XForce USA
XForce-USA
May 23, 2016 03:50 PM
XForce USA
XForce-USA
Apr 13, 2016 07:42 PM
XForce USA
XForce-USA
Mar 7, 2016 10:53 PM
JonMotoring
Lancer Vendor Classifieds
Sep 10, 2013 01:43 AM
