JTCB's Turbo Build
JTCB's Turbo Build
Alright guys so I've been thinking a lot about going turbo. I'm pretty new to forced induction so bare with me. I found this eBay turbo kit that can be shipped for 550$ to Canada I think its pretty interesting. So from what I've read other than rebuilding the turbo properly, cuz they tend to break a lot, everything else should be ok.
For the moment Im thinking of running the kit at a low 5-6 psi until I do head studs and mabey block work!
So I'm not gona pushing the kit all that much and then as time comes i'll have to replace parts here and there but ill be able to boost!!<3
This is everything that is included in the kit
1 X T04E Turbocharger
1 X External Cast Steel Wastegate WG
1 X Type-S Blow Off Valve Kit
1 X Flange Pipe
1 X Adjustable Boost Controller
1 X Manifold Wrap
1 X Programmable LED Turbo Timer
1 X Adjustable Fuel Pressure Regulator
1 X Braided Oil Feed Line
1 X T3/ T4 5-Bolt Flange
1 X Lightweight Aluminum Intercooler
1 X Set of Aluminum Piping
2 X 90 Degree Pipe
2 X 45 Degree Pipe
2 X Straight Pipe
8 X Silicone Hoses
16 X Bolt-Tight Clamps
After that I would be missing
WRX 425c Injectors
Walboro 255 fuel pump
Custom Turbo Manifold & DP
AEM Wideband
Fittings and hoses
New HACKISH Reflash
Turbo Rebuild
Evo 8/9 3 BAR MAF
So I really wanna know what you guys think before I go ahead and do this. I was also thinking of ordering the kit and maybe just buying a ball bearing turbo and sell the cheap turbo. Everything else in the kit seems legit from what I know. Let me know if I'm forgetting something!
I think I can get this done for 1500-2000$ It would be great for everyone if we could get this to work properly.
This is the site for the turbo kit for more precise information
http://www.ebay.ca/itm/T04E-12PC-T3-...64b4e0&vxp=mtr
Package Includes:
1 X Flange Pipe
1 X Manifold Wrap
-Piece Piping Set Includes:
2 X 180 Degree U-Pipe 2 X 90 Degree Pipe
2 X 45 Degree Pipe
2 X Straight Pipe
8 X Silicone Hoses
WRX 425c Injectors
AEM Wideband
Fittings and hoses
New HACKISH Reflash
Turbo Rebuild
Evo 8/9 3 BAR MAF
I think the kit will be fine..the turbo is not that reliable but I have seen people that have had no issues with the ebay turbos. All you ic piping will need to be cut and welded to fit and with a custom manifold everything can work great. In the end its all up to you bro...good luck with your build
Yeah anyways i'm not really worried the turbo is gona be pushing 5-6 psi until I get a sicker one. For the rest of the kit.. I think it should last as long as its installed and tuned properly!.
Yeah I will do my best! Still saving up for the project. I've never studied so hard in my life aha :P
Nice!!!!!! Cant wait to join the Turbo RA scene, you gotta be sitting somewhere around 250whp!!
don't run a ebay turbo kit they're **** go to a speed shop and get a legit set up I just upgraded my turbo in my evo 8 and I went to a local shop where I know the owner and he hooked me up
THIS MIGHT WORK????
http://www.ebay.com/itm/WOW-2006-2012-4G-Mitsubishi-Eclipse-GS-4g69-Cast-Iron-Turbo-Log-Manifold-/151101932701?pt=Motors_Car_Truck_Parts_Accessories&hash=item232e60849d&vxp=mtr
I had one of those...
https://www.evolutionm.net/forums/04...-manifold.html
you might get away with pusher fans...or even a half rad...but no guarantees, look at the engine bay pic, take note of the upper rad hose, it barely fits the eclipse (for which it was designed) which has way more clearance up front than we do...I know for sure it won't work with the stock rad and fans...furthermore it requires a more complex downpipe, if you opt to use an external wastegate...unless of course you dump to atmosphere...and T3 internal wastegates come with extra cost, and possibly more fabrication...
talk to Chase, aka beautifulpunk...he's doing some nice work on manifolds, and his prices are more down to earth...or do what I did, make it yourself, borrow a portable gasless welder, tack weld the way you want it, and then take it somewhere to have some beads run...if you do the measuring, cutting and fitting yourself, it's not too much to pay for the welding...
So I talked to Chase. He said he can make me a log manifold like the one you have for 350$ + shipping. Alot cheaper then all the other alternatives and the route I will be going. I just don't know with the universal kit if everything will fit between the bloc and the fans.
