Another Hackish ECU Reflash Review
After some difficulties getting the ECU to me and the snowstorm delaying it I was finally able to install it on Friday.
2006 RA 5 speed manual
My Mods are:
Underdrive pully
Short Ram Intake
Exhaust header/downpipe
And a custom exhaust with no cat convertor (illegal in PA )
ECU tuned specifications:
93 Octane
Speed limit removed
Rev limit increased to 7200
Lower CAT effeciency code to come on
Mivec was not changed
And 2-Step installed and set for 5,000
After installing I let the car idle and get used to the cold weather and learn. I then had to go to work so I really didn't punch it or anything. I didn't notice anything different except that I was idling about 100-200rpms lower. Later on after work I did some testing. I opened her up on some of the back roads, I didn't really feel a power difference still, but when Mivec engaged I felt a jolt and it felt like the car lost a great deal of HP and like it was being held back. So I figured maybe it just needs to learn some more and went home.
Over the weekend I kept pushing on it, keeping it in Mivec to let the ECU learn it. After doing that for a while the car has gained a lot of horsepower, it is still acting strange once Mivec engages. Not as much power loss but its there.
The 2-Step works wonders (first time ever using/being in a car with it) It made me get pushed back into my seat when I launched. So I know that is working.
So other than the Mivec problem I have to say, anyone that is considering this, I would say go for it! I am currently emailing Hackish back and forth about the current issue, hopefully soon to be resolved!
I give it a 9/10, when problem is solved I'll glady give it a 10/10
Edit: Important! I may be jumping the gun, but its been 2 days and Mivec is working It happened after my oil change, and I decided to have some faith in my car haha. To my belief I didn't lose power when mivec engaged!!! So the past 2 days I've been pushing my car to mivec, it has yet to decrease in power. Well second gear seems a little slow but third picks up the slack. On my way home tonight mivec seemed to have a little more power, I was able to get up to 80 insanely fast, I think I have awakened a sleeping beast!
I talked to Michael about that, he said how it seems our engines are oil sensitive. I know I may be an idiot for this but I was putting 5 quarts of oil in my car, but this oil change I put 4. So I'm assuming we take 4 quarts (couldn't find it anywhere) he also said that my filter may have been clogged also, I didn't really check for that when I changed the oil though.
So here is to my awakened beast!
My Mods are:
Underdrive pully
Short Ram Intake
93 Octane
Speed limit removed
Great!!! I have mine on the way With similar opitions I also raised the rev limiter to 7200, my 2 step is set to 4000 rpms , I raised my idle to 1000 for the cam coming... But it sounds good overall , I'm kinda a bit disliking about the feel of lost hp though that's not what I want ... Hope it all works out and I hope I get mine soon.
Well the hp loss is only in mivec, there is significant power with the flashed ecu though. My car is just being stubborn. I did reset it and it seemed to help a little so maybe after a little more it will stay a constant power all the way.
Well hackish told me he tested it at 7500, and it was fine. He said 7200 is more of a safe area. But I have yet to push it constantly to 7200.
I know as I've been trying to get the ecu to learn mivec, I've been running the backroads at 5-6000 lol. Crazy backfire when I let off the gas
The stock still revs up to 6900 I don't think that is going to destroy anything going up 300 rpms more like something to brag about lol... The no cat is illegal in all 50 states btw lol. And based on ralliarize it ecu it just takes a few days to adapt to the environmental changes. Like -10 Canada to 70 Miami is going to be a big change.Keep us posted
A two step- I'm not sure if there is too much more to it but here goes. Hold in the clutch, push the gas and your car will rev to whatever limit you set, I have 5,000. So as I hold down the clutch+gas it wont go above 5,000. Now slip the clutch a little and go! Remember to shift As you let off the clutch and go your engine will rev above 5,000 and continue as normal as you shift. Now I'm not sure if anything special happens with N/A but I read I think somehwere on the forums when you have a turbo, it will build up your turbo for a nice launch. And believe me, the car launches with a two step
I tried explaining the best I could, hopefully you could follow me.
Well I guess you could do that, but let's say you're at a strip and you're watching for the light. How would you watch both at the same time?
Haha don't worry, I'm the same way. I've been driving a stick since 16. I rarely look at the rpm gauge. I know the sound of the engine and when to shift. Unless I floor it, then I look.
wow thats low! To be honest I wasn't sure what to set it at. I had never owned a car with 2-step. I didn't know too much about it, I figured around there would be good since Mivec is engaged after 4. But I guess it also boils down to personal prefrence?
