The Official Ralliart NOOB Thread
Old Jun 18, 2013, 07:22 AM
  #691
icrnk's Avatar
Originally Posted by Raikiri
You must be looking at the lights for the cars without the sunroof. Assuming you have the sunroof, the bulb size for the dome/reading lights are going to be 2825. If you decide to get LED bulbs then use 194/168 size bulbs.
I got those for the Sportback
LUMEN® 125CW - Interior Dome Light Replacement LED Bulb (1.25" / 32mm / DE3175, White) http://www.carid.com/universal-led-l...s-3049470.html
A little long but it still fit fine.
Got this one for the trunk/cargo light
LUMEN® PL125CW - PlaZma Series Interior Dome Light Replacement LED Bulb (1.25" / 32mm / DE3175, White) http://www.carid.com/universal-led-l...-10609328.html
Look well made and nice bright light.
What is the replacement rear parking/turn signal bulb on the sportback? It's theamber bulb. I saw 992 (7440A) as the bulb but I don't think it has a flat base like this:
It looks more like an 1156 amber bulb
Old Jun 18, 2013, 08:08 AM
  #692
Raikiri's Avatar
I've used absolutely none of those (aside from the trunk bulb) but I'm not sure how much they changed it up from the sedan versions...
Idk about the turn signal as thats the only bulb I never changed just because I dont want the car think that it's burnt out and flash faster when it'd just be an LED bulb.
Old Jun 18, 2013, 08:24 AM
  #693
icrnk's Avatar
I agree about LED on turn signals. I really just want to change the amber bulb to a yellow bulb on one of the ones that appear chrome, but flash amber.
Old Jun 19, 2013, 08:07 AM
  #694
lbwilliams44's Avatar
Yeah the trunk one is the same, I ended up going with this one: https://www.superbrightleds.com/more...edge-base/214/ for my dome light, its way to big to fit in there but I cut away a bit of plastic and it is pretty awesome. I can see everything at night.
Old Jun 26, 2013, 12:42 PM
  #695
gordito_mivec's Avatar
I have this LCA (control arm) for Lancer 2002-2006 for sale! Im the only one with this if youre interested let me know.
thanks $325.00 plus Shipping
http://www.ebay.com/itm/271229242229...84.m1555.l2649
Old Feb 1, 2014, 12:20 PM
  #696
Triad's Avatar
i got to page 18 and got tired of reading.. (being honest here) So I dont know if this has been asked or not.. Will a 02-06 OZ rally catback exhaust fit a 05 ralliart?
Old Feb 23, 2014, 09:02 PM
  #697
Anybody know if Valve Springs from a 4G63 will fit on our RA?
Old Feb 28, 2014, 08:22 AM
  #698
darryld's Avatar
Will either of these lights fit on my 04 ralliart?
http://ontario.kijiji.ca/c-cars-vehi...AdIdZ567361737
http://ontario.kijiji.ca/c-cars-vehi...AdIdZ564503724
I like the ones from RRM but a bit to pricey imo.
Thanks for the help.
Old Feb 28, 2014, 08:50 AM
  #699
bakuro117's Avatar
Neither of those will fit the RA. You have to get ones made for the 04-06 models. 03's wont work unfortunately.
Old Feb 28, 2014, 08:53 AM
  #700
darryld's Avatar
Okay thanks for the help.
Old Jul 29, 2014, 12:52 PM
  #701
Just want a yes or no answer on this:
Any body part that fits a standard Non-Evo lancer fits the ralliart correct? Hood/trunk/panels?
Old Jul 29, 2014, 01:07 PM
  #702
bakuro117's Avatar
If it is from the 2004-06 years then yes. All the panels should be the same. If its 02-03 then no.
Old Jul 30, 2014, 07:26 AM
  #703
Yeah that is what I assumed. Thanks!
Old Apr 25, 2015, 10:43 PM
  #704
GustavoC's Avatar
Could someone please help me point out where in the engine is the Throttle Position Sensor located at in a 2004 Ralliart. I have absolutely no clue, I am getting error code P2138 from autozone, and the technician was not as helpful.
thankks!!!
Old Apr 26, 2015, 04:38 AM
  #705
CrAnSwIcK's Avatar
thankks!!!
It's your accelerator pedal position sensor, the thing your throttle cable connects to behind the passenger side head light. did anyone ever screw around with the adjustment? disconnect your negative battery terminal, unplug the connector from the APPS, inspect pins and wiring for corrosion or damage...reconnect the sensor, reconnect the battery...
you need to search...posting here is not too bad, but posting this question in someone's show and shine thread is highly inappropriate, and people aren't going to help you if you just flood the forum with your garbage...
I don't know if this will work, but try this:
https://www.evolutionm.net/forums/se...rchid=21587806
Showing results 1 to 11 of 11
Search took 0.05 seconds; generated 4 minute(s) ago. Search: Keyword(s): P2138
Quick Reply: The Official Ralliart NOOB Thread
