OEM Ralliart Part Number Questions
#259
I need a pn for a piston, bearings, piston ring set, head gasket kit, hub assembly, oil pan and the the studs on the intake side if possible. I'm sry its so much but I have a lot to do. Please and thank you
#260
oil pan - MN195078
upper rebuild gasket kit - MD979393
intake side studs (3) M8x28 - MS401428
nut for above studs M8 - MF430151
washer for nut - MF450405
front hub - MR519923
rear hub - MR527453
#265
I tried to search but I can't find the part number for the front strut mounts. Anyone want to chime in?
EDIT: I found Ebay KYB Strut Mounts. Is SM5461 the correct product number?
Last edited by kapitolralliart; Sep 18, 2012 at 12:54 PM. Reason: Found it...I think.
