Aggressive Wheels on 2004-2006 Lancer
Old Apr 22, 2012, 05:34 AM
  #256
nc_bboy's Avatar
Originally Posted by keithislegit
I'm actually running a 215/50/16 now on my 16x8's. I haven't gotten around to pulling the rears but on the front I rub at full lock only in reverse. I'm waiting until I lower my car to decide if I want to stick with the 215/50 or lower it down to a 215/45. Ill show you a picture hold on. I just have to figure out how to put it on here.
As you can see, the stretch isn't to bad. I'll take some more pictures later. This one wasn't so good because I was in a rush to get back to work. lol.
Oh ok i forgot you were running a 215/50. Nice rims btw! Ok so are you running a 5mm spacer or 10mm spacer? It might be the difference between you rubbing really bad or barely rubbing. 16x8 +35 with a 3mm spacer will clear and drive safely. Only reason i know this is true is because the people are running a 17x8.25 +35 with 3mm spacer and all they have o do is a slight pull in the rear. So a 8" rim should be about the same with a 5mm spacer. With a 10mm spacer you will have to pull more, plus you will have to take into account how big the sidewall is on the tire.
Old Apr 22, 2012, 08:28 AM
  #257
keithislegit's Avatar
I've actually taken off my rear spacers. And put my stock rims back. It was a 5mm and it barely cleared so I'm trying to get a 8 mm spacer custom made so I have an exactly +35 offset. The rims I have right now are +42. My old bbs's where 16x8 +35 and it fit without any spacers. It might have fit because I used a tire without a rim protector which gave me a slimmer sidewall and maybe because I was running a stretched 205/55 on it. and it All I needed was just a roll.
Old Apr 22, 2012, 03:39 PM
  #258
nc_bboy's Avatar
Oh ok, that makes sense then. I didn't realize you had 42 offset. Yeah for an 8" anything from 35 and lower will clear. You should post up some pics of your rims. I should have pics of my new setup by my birthday lol May 3! I'm still saving for my coilovers. Lol
Old Apr 22, 2012, 06:08 PM
  #259
I will post some pictures soon. I currently only have two bbs's mounted on my car right now. Lol. Here's a picture of the "stance." Don't mind the battle scars. Some lady cut my off and made me ram into a gaurd rail. Luckily I didn't have my Bbs's on at that time. Sorry about the phone quality pictures. I don't have money for a professional one. -_-"
Old Apr 22, 2012, 07:09 PM
  #260
deathsythe99's Avatar
im getting toyo R888 tires. ony bad thing is their 255/40-17 how far would i need to roll my fenders on 17x8.25 wheelsl?? getting them for dirt cheap literally for dirt cheap but i dont want to do it if they require too much rolling or huge spacers
Old Apr 22, 2012, 08:21 PM
  #261
nc_bboy's Avatar
255? Lol I'm not sure about that. I know someone had a problem with the stock evo wheels with the stock evo tires and it was rubbing like crazy. I believe they were like 235. Might need a spacer and a pull.
Old Apr 22, 2012, 08:48 PM
  #262
Raikiri's Avatar
i dont think 255 willl be very nice to your car lol. pick up the wheels. sell them for profit and buy other tires like some 215s!
Old Apr 22, 2012, 09:04 PM
  #263
215's is what i want to go with but no one here knew about the tires i want.
these
http://www.tiresplus.com/tirecatalog...article=125282
Old Apr 22, 2012, 09:28 PM
  #264
Raikiri's Avatar
not sure how i feel about the reviews im reading on those tires. pick up some s-drives!
Old Apr 24, 2012, 03:58 PM
  #265
i have to see how this weeks check will be but i dont plan on track with these rims.
also i heard xxrs bend easy is it true?
Old Apr 24, 2012, 05:24 PM
  #266
Raikiri's Avatar
idk but i dont track these rims either so not planning on finding out
Old Apr 24, 2012, 07:19 PM
  #267
ive been reading bad reviews on yokohama s-drives like low mileage for life time
Old Apr 24, 2012, 07:48 PM
  #268
The people who write those bad reviews about good tires don't know why they're designed the way they are. Some tires arnt meant to be ran year round, some tires arnt meant to be drivin in the rain or wet surfaces. Tires that are meant for racing arnt meant to have good tire life. If you're looking for an economical tire, don't go for v rated tires. Go for tires that are meant for good gas milage and are meant to be ran year round. In conclusion, racing tires = good grip, good for track/racing, good for summer or warm climates, bad for winter, bad for tire life, bad for gas milage.
Old Apr 24, 2012, 09:19 PM
  #269
Raikiri's Avatar
which is why i have my other set of wheels with all seasons g-force supersports
Old Apr 25, 2012, 02:45 PM
  #270
on your stock rims? or your xxr's that the g-force are on.
Quick Reply: Aggressive Wheels on 2004-2006 Lancer
