Aggressive Wheels on 2004-2006 Lancer
Old Apr 21, 2011, 12:34 PM
  #31
Cj98's Avatar
I'm looking to pick up some tein coilovers and Rota's 17x8 35+ and would like to fit some 215's or something a bit meatier.
Old Apr 21, 2011, 05:51 PM
  #32
k3lv's Avatar
meatier as in profile wise or width wise? Don't think you can go any wider without hitting your stock fender, and profile wise I wouldn't suggest higher than a 40 series, you're getting coilovers because you want to go lower right? By having a meatier 45 series tire you'll run into a whole lot of rubbing issues
Old Apr 23, 2011, 10:45 PM
  #33
Cj98's Avatar
I want to get coilovers for adjustability and I would believe that I could clear a 225 tire. I am getting the car repainted so I can pull the fenders as well if need be. I want to be low but not tucking tire
Old Apr 24, 2011, 12:46 AM
  #34
k3lv's Avatar
So what exact size are you looking for?
225/45/17: Way oversized throwing off your speedometer. There will be LOTS of rubbing with this size. The rubbing would most likely rub the fender liner inside. And what coilovers will you run? Will the camber be adjustable?
225/40/17: Last time I checked this size only existed with Nitto Neogens, but I don't see it on their website anymore
Is there a reason you're wanting to run such a thick tire? I still suggest staying within 2% of the stock tire size
Old Apr 24, 2011, 09:37 AM
  #35
Cj98's Avatar
The coilovers are tein basics. What about a 215/40-17? I'm certain on the wheel size.
Old Apr 24, 2011, 01:37 PM
  #36
k3lv's Avatar
^ CJ I've always said that 215/40/17 is the magic tire size for us. Close to speedometer reading and good fitment option
Old Apr 29, 2011, 06:36 PM
  #37
JoshMFSanchez's Avatar
what does an aggressive wheel set up do?
Old Apr 29, 2011, 07:12 PM
  #38
EvoM Super Moderator
lanzerralliart's Avatar
It makes panties drop or become non-exsistant, so say better handling can also be had..
Old Apr 29, 2011, 07:20 PM
  #39
ahh haha.. the handling seems unimportant
Old Apr 29, 2011, 10:40 PM
  #40
SyZyGy1394's Avatar
Only will really happen when you run an "aggressive" tire, not wheel. I lol at people running wider wheels that run tires that will fit on the stock size wheel. FAIL
Old Apr 29, 2011, 11:30 PM
  #41
Flip's Avatar
THIS!!
just buy my wheels, they looked hella nice on my RA when i had it. info is in my for sale thread.
Old Apr 30, 2011, 01:12 AM
  #42
k3lv's Avatar
No disrespect but this is obviously not the "aggressive tires" thread, I understand some people use their car to track, some people use their car to show off and be unique/look good as a daily street car. You're right it doesn't make it handle better, like I said it all depends what they are aiming for. Please just leave useless comments out of here, I just created this thread to share info/opinions based on experience.
Old May 3, 2011, 07:28 PM
  #43
deathsythe99's Avatar
ok guys i need some help a guy in colo. (which is where im at) is selling some ssr GT-7 wheels 17" x 8" 8 1/2" silver 5 x 114.3.
Two of the wheels are 17" x 8.0", 40mm offset; two of the wheels are 17" x 8.5", 40mm offset. The hub centerbores are 79.5mm.
so my question is what could i do? in other words like have the 8.5 upfront and 8.0 in back or vice versa their nice and he is selling them cheap i dont understand all the 40mm and 79.5mm things (havent studied )
what tires would be good also? they only weigh 17 3/4 lb
also i have the kyb shocks and tein s tech's
thanks.
Old May 4, 2011, 03:03 PM
  #44
bump please
Old May 8, 2011, 09:35 PM
  #45
k3lv's Avatar
sorry late reply I went on vacation. Your 8.5 definitely won't work, you'll need a lot of work to fit that, and I'd imagine you would also be sitting very close to the suspension with that. I'd pass on that setup unless you want your wheels further out and get body work done
Quick Reply: Aggressive Wheels on 2004-2006 Lancer
