Ralliart Big Brake Upgrade
I don't anticipate a problem with either. That being said, if you do upgrade the pads in the front, do so in the rear as well! Thank you for bringing that up.
I will test all of this VERY THOROUGHLY before releasing anything. Like I said, this will be done as safely as possible for both you and your cars.
Some more good info:
A good Evo 8/9 front rotor is the Centric Premium part #120.46064. (Same as stoptech)
They cost around $70/each on Amazon, etc
So about $140 for a pair. I've used these for years on my Evo 8 and have stood up just fine to track abuse as well as street.
So put the package together with all new parts:
1. Centric Premium front rotors part #120.46064 x2 - approx $140 for the pair
2. PBR C5 front calipers (no corvette logo) $299 or $334 for stiffer C6 versions
3. NFSLancerRA's brackets -$150
4. NFSLancerRA's SS brake lines - approx $80
Front kit = $669 w/C5 calipers or $704 w/C6 calipers. + whatever brake pads you prefer
Not a bad deal.
RA rotors = 11.6in
Evo 8/9 rotors = 12.6in
Not bad for 1in more rotor and stiffer/larger calipers
Not a bad deal.
RA rotors = 11.6in
MRT uses the C6 calipers, so same if you spend the extra $34 or so for the C6's
Edit: It looks like the MRT kit uses larger rotors then the Evo 8/9, at 13.77in dia, which happens to be the same size as the Evo 10 rotors.
NFSLancerRA, maybe make a bracket approx 1" longer to fit the Evo 10 rotors? Or do two options?
A lump just formed in my stomach. This is either really good news or really bad news. This MIGHT mean that you won't need brackets to run this setup. I really hope that that is what it means. It also means that we may need to go bigger with Evo X rotors. That isn't a big deal. I will pick up a set tomorrow, hopefully.
Hold off on buying the parts listed above. My car goes in on Thursday. I will know more then.
I looked at the pictures. That bracket looks like it spaces the caliper out an inch and change. That is exactly the difference between the 8/9 rotors and the 10 rotors. After all, the Corvette did come with rotors that are approximately the same size. The issue is going to be offset. However, this may be a whole hell of a lot easier than I thought that it was going to be. It may be harder, too. We'll see. I may need to go with Evo X rotors, which is a bridge that I will cross when I come to it. One way or another, this will get done.
