Ralliart Big Brake Upgrade
#31
I looked at the pictures. That bracket looks like it spaces the caliper out an inch and change. That is exactly the difference between the 8/9 rotors and the 10 rotors. After all, the Corvette did come with rotors that are approximately the same size. The issue is going to be offset. However, this may be a whole hell of a lot easier than I thought that it was going to be. It may be harder, too. We'll see. I may need to go with Evo X rotors, which is a bridge that I will cross when I come to it. One way or another, this will get done.
I'm sure you will need brackets either way as even the Evo 8/9 rotors are 1" larger diameter then the RA rotors.
Personally I think if you can get the Evo 10 rotors to work with not much more fuss I would. Since the RA weighs basically the same as the Evo 10, it would be nice to have the same heat sink size as them.
It's your project though.
#38
yeah, i was just eye balling those on ebay... 1100 - 1300 for all 4 corners; calipers only; 6 pot fronts and 4 pot rears...
but they be balllin'
Personally, I think I'd be happy w/ the regular C5/C6 calipers on X rotors; until I win the lotto
#41
No one needs to send me anything. Thanks though. I just need to find a set of Evo X rotors. This may have to be postponed until I can do so. I was fine running the Evo 8/9 setup, because it allows you to run 17" wheels and is considerably less expensive. But, I will push for larger rotors.
#45
Again, this is your project, but I figured any little bit of info might be helpful.
