Ralliart to EVO wheel hub boot upgrade?
Old Oct 30, 2016, 05:54 PM
JBN
JBN's Avatar
I have a 2011 Ralliart Sedan. Does anyone know if the EVO 10, or MR (or other EVO) front wheel hub knuckle is compatible with my Ralliart? I want to change to a bolt on type wheel hub since my stock front hub is a pressed part and therefore harder to replace without a press. The rears are a bolt on type, but unfortunately the fronts are pressed parts.
I track the car about once a month and I have had to replace the front left hub twice. I want to upgrade to a sturdier, bolt-on type and I am thinking the EVO has a bolt-on type compatible with the Ralliart.
Any info would be helpful.
JBN
Old Oct 31, 2016, 06:14 PM
JBN
JBN's Avatar
I meant front wheel hub knuckle upgrade for Ralliart
I meant front wheel hub knuckle upgrade for Ralliart.
Old Feb 2, 2017, 04:09 PM
Rival Legendary's Avatar
JBN
what symptoms were you having that required you to replace your hubs/bearing?
Old Feb 3, 2017, 12:35 PM
JBN
JBN's Avatar
The hub sheered off the spindle!
Old Feb 3, 2017, 12:57 PM
LiX
LiX's Avatar
Evo X front knuckles will fit on RA with additional spacer on the locking nut. However the mounting holes for the calipers are different. Evo X is using 160 mm between mounting holes vs. 130 mm for RA.
deanmeon
20
Mar 5, 2014 03:09 PM
NocturnalEVO
19
Jan 20, 2013 06:57 PM
Touge Factory
Sep 14, 2009 02:01 PM
Mitchubishievo
15
Oct 15, 2008 11:02 AM
Quick Reply: Ralliart to EVO wheel hub boot upgrade?
