Ralliart (AUS) ECU Stuff For Dummies
Old Feb 11, 2012, 07:04 PM
  #61
210ralli's Avatar
Originally Posted by richardjh
I'll go make a 56940010 definition on goldenevocom. Perhaps just a cut-down place-holder, but it will do the trick for allowing people to "reflash to stock" without xml hacking.
Rich
I just went to goldenevo website and noticed that the new one was up there but it shows rom id 56940009.. Shouldnt it be the 56940010 for the 2011?
Old Feb 11, 2012, 07:07 PM
  #62
richardjh's Avatar
Look again! Both are there now.
(I was in the middle of doing it when you looked )
Rich
  #63
TurtleRA's Avatar
Just looked, it is there, maybe hit refresh.
Old Feb 11, 2012, 07:11 PM
  #64
210ralli's Avatar
Just saw it.. Nice work making it easier on the the newbies like myself!
Old Feb 11, 2012, 07:24 PM
  #65
richardjh's Avatar
No worries. Those new defs are still a bit thin for full-on tuning work, but it won't take much to bring them up to scratch.
Rich
Old Feb 28, 2012, 06:43 PM
  #66
210ralli's Avatar
so I tried logging today for the first time using evoscan, I checked off all the boxes shown on the gst basemap thread, but when I went to open the logs it displays 'power/torque graph warning: tps>80 or missing APP >80 ' It will open some stuff up but doesnt show any of the info on the graphs. Any ideas for what I am missing here?
Old Feb 28, 2012, 07:29 PM
  #67
richardjh's Avatar
Can you upload your log file? Or the first few lines of it, anyway?
Rich
Old Feb 28, 2012, 08:04 PM
  #68
210ralli's Avatar
here is a 3rd gear pull I did, I just renamed the file to the .zip to upload, I guess you can rename it to .csv to open in evoscan. Let me know if this works.
Old Feb 28, 2012, 08:05 PM
  #69
210ralli's Avatar
Also I didnt do standalone logging, I had tactrix plugged into laptop while logging with evoscan, dont know if that makes a difference.
Old Feb 28, 2012, 08:53 PM
  #70
richardjh's Avatar
Your TPS is locked at 111.2941, so the logging setup for TPS isn't right for your ROM.
Evoscan is probably failing a sanity check on that...
Rich
Old Feb 29, 2012, 02:57 AM
  #71
210ralli's Avatar
Do you know how to correct that, is it within the rom itself or within evoscan?
Old Feb 29, 2012, 03:00 AM
  #72
richardjh's Avatar
99% sure it's a wrong address for TPS in Evoscan... as in, wrong address for your particular ROM. You need to find the correct address and update the "RequestID" field for TPS...
Rich
Old Mar 1, 2012, 01:21 PM
  #73
crak's Avatar
You know how you get the CEL after using ecuflash. With the old version you could go to ECU > Clean CEL's...now in teh new version there is no option for clearing CEL's. advice?
C
new ecuflash is here: http://www.evoscan.com/free-ecu-rom-downloads
Old Mar 1, 2012, 02:45 PM
  #74
richardjh's Avatar
That's why I'm not upgrading!
Rich
Old Mar 1, 2012, 06:06 PM
  #75
nunyas's Avatar
ah yeah, that's slightly annoying, but, since I usually crank up EvoScan right after I flash my ROM to do some logging, it's not that big of a deal, because I can clear the codes w/ EvoScan.
Quick Reply: Ralliart (AUS) ECU Stuff For Dummies
