HOW TO: TPMS FIX with aftermarket / winter rims.
Old Jan 2, 2010, 04:29 PM
laflsyl10's Avatar
The following is to fix that annoying warning that everyone gets when they change or swap rims. For myself this solution is cheaper than swapping the sensor from my winter rims to my summer rims. The materials cost 12 $ and this is a one time thing.
Here is what you will need.
1 pvc pipe adaptor 4".
1 pvc cap 4".
1 abs plug 4".
pvc cement.
1 valve stem.
You will also need the following items.
Drill, drill bits, pliers and 15 minutes of your time.
1- Here is the material needed.
2- Drill the pvc pipe anywhere, you will need this hole to insert the stem. The size will vary on the size of the stem that you will select.
3- Put cement around drilled hole.
4- Insert valve stem and pull tightly with pliers.
5- Put pvc cement around cap and adapter section.
Note. The cement smells really strong and this should be done in a well ventillated area.
6- Insert cap on the end.
7-Finished product, you can paint it any colors you like.
Then you simply put your sensors inside the canister with cotton *****, and inflate it to the required psi. You toss that thing in your spare tire storage and your car will think your tire pressure is alright. No matter how many times you change your tires, rims or swap from winter to summer, you will not have to pay that dude to re-install those sensor on your new rims everytime. If you ever have any problem or need your sensor for anything, simply unscrew the top of the abs cap and voila.
Enjoy
Enjoy
Old Jan 2, 2010, 04:39 PM
xtmx's Avatar
Have you tested this? I was under the impression that the spinning motion activated the sensors?
Old Jan 2, 2010, 04:55 PM
boostin20's Avatar
You sure about this?
Old Jan 2, 2010, 05:20 PM
laflsyl10's Avatar
Why wouldnt this work, i had my summer tires in my car today, the havent been on the car for 2 months, and the warning did not come on when they were in my back seat. They havent been rotated or spun in a while!
Old Jan 2, 2010, 05:26 PM
boostin20's Avatar
Ok, good enough for me. Thanks.
Old Jan 2, 2010, 05:31 PM
Taranis's Avatar
Yeah it should work at least conceptually. Pretty neat idea overall for anyone who does not want TPMS working for whatever reason!
-Taranis
Old Jan 4, 2010, 07:33 AM
Bom's Evo's Avatar
HAHAHA! That's pretty funny!
Very Cool too!!
Old Jan 4, 2010, 08:36 AM
bmanuhutu's Avatar
some guys over at the lexus forums tried this as well, they painted the canister for the full effect
http://www.clublexus.com/forums/is-s...pipe-bomb.html
Old Jan 4, 2010, 01:42 PM
toredefine's Avatar
Amazing. Thank you!
Old Jan 4, 2010, 09:15 PM
Chops's Avatar
nice work sir! why stop at a little canister though? really take it to the next level and make it look like a n02 bottle or something for a joke! Capacitor? fire exinguisher? the possibilities are endless!
Old Jan 5, 2010, 07:07 AM
laflsyl10's Avatar
Those are all neat and cool ideas, except mine is going to be hidden so there's is no point in making it pretty. You can always post pictures of your unique ones!
Old Jan 5, 2010, 08:59 AM
RADriver's Avatar
nice work sir! why stop at a little canister though? really take it to the next level and make it look like a Capacitor?
A Flux Capacitor! That is hilarious! Caution 1.2 Gigajoules
Old Jan 5, 2010, 12:30 PM
djson80's Avatar
Nice!!! I am just about to switch out the stocks for some Enkeis and have already had enough of that annoying warning going off....
Question. Are the sensors inside the stock tires? Or are the bolted on the back of the rim? Or???
Old Jan 5, 2010, 02:07 PM
velocityhead's Avatar
They are attached to the rim via the valve stem, kind of like this:
Attached Thumbnails HOW TO: TPMS FIX with aftermarket / winter rims.-tpms8.jpg
Old Jan 5, 2010, 02:22 PM
03chi-town0Z's Avatar
pronounced: Jigga - Watts. get with your 80s movies man.
ill definitely be trying this one. tonight if all goes well...
Quick Reply: HOW TO: TPMS FIX with aftermarket / winter rims.
