Driving with a bad alternator? need help quick
Old Mar 26, 2010, 07:09 AM
SnowEvoVIII's Avatar
Post Driving with a bad alternator? need help quick
11 hours from home. Alternator is dead from what I can see. With jump starts at gas stations, can I make it home freeway driving? I'm pretty sure I know my answer, but I need to ask regardless
Old Mar 26, 2010, 07:23 AM
Bobster22388's Avatar
I'm going to say no here. There is no way for the battery to recharge. Which means all of the electronics in the car are going to go out and the engine will just stop running.
Old Mar 26, 2010, 07:45 AM
silverIXMR's Avatar
yea once the battery dies the car wont jump start anymore if the alternator is bad too. put a multi tester on it when its running if possible.if you get a little over 14volts then you just need a battery and the jump starts should get you home. if it is under 12 volts call AAA. good luck bud
Old Mar 26, 2010, 08:07 AM
churbo's Avatar
This is ghetto....ghetto buddy but I've done this before. I put a jump box on my car and just left it on there.....I was able to close the hood(wasn't on an evo) and I was able to get where I was going.....I only went like 5 to 10 miles though. That's a lot further. Towing it would be your best option.
Old Mar 26, 2010, 08:29 AM
Poik242's Avatar
11 hours, no way.
Old Mar 26, 2010, 08:50 AM
churbo's Avatar
haha I told you it was ghetto! Just stop at Napa or Autozone or O'Reileys or any parts star and see if they can get you an alternator and let you borrow some tools. Not a hard install.
Old Mar 26, 2010, 08:53 AM
Genesis8's Avatar
Yep, no way.
Originally Posted by Poik242
11 hours, no way.
Old Mar 26, 2010, 08:57 AM
churbo's Avatar
Hey OP where are you at? I seen you are from CO, I'm station in SD if you are anywhere around this area i.e. a few hours away let me know.
Old Mar 26, 2010, 09:19 AM
glgz's Avatar
I would say you could go maybe an hour at most with nothing on in the car if that. 11 hours no way. I would just by a new one and put it on. I changed on the side of the road once on my old Z-28. I didn't have a choice has it locked up and wouldn't let me even turn it over.
Old Mar 26, 2010, 10:40 AM
jestoy7's Avatar
Are you sure it is the alt and not a bad ground or bad battery connection? These can cause symptoms of a bad alt too. Worth checking, good luck!
Old Mar 26, 2010, 11:12 AM
JakeTheVIII's Avatar
Ok here's what you do. Use a power inverter inside the car to plug into cig lighter, plug in your jumpbox to the inverter, hook to the battery, should be good to go.
Just kidding. There's no way you'll make it 11 hours. One battery would die within an hour. Use a generator inside the car! It's gonna be a long way home. If towing it is not an option, drive as far as you can, stop and charge, repeat.
Old Mar 26, 2010, 11:15 AM
churbo's Avatar
Good point! We all took his word that it was a bad alternator when it could just be a loose/bad connection.
Old Mar 26, 2010, 01:33 PM
EvoVan's Avatar
You wont be able to get more than an hour out of her.
Old Mar 26, 2010, 01:35 PM
Poik242's Avatar
On an 11 hour trip you will spend more time recharging the battery and stopping than it would take to just replace the alternator.
Old Mar 26, 2010, 02:18 PM
blas4's Avatar
No way its gonna last 11 hours. I had the same problem with my explorer, but after about 30 mins city driving, all gauges died, everything, and the car was sputtering all over, but just made it home.
And im sure the evo needs a lot more electronics to run properly so..
Quick Reply: Driving with a bad alternator? need help quick
