Help on AEM EMS series 1 30-1313 install on evolution 5
HI to every one here im new to the forum and to share my projects and goals with other evo lovers.
for the moment i have a evolution 5 and i want to use my old evo 8 AEM EMS edu hope someone here can help me with these on what pins i have to change on the wiring harness edu to make it work
thanks a lot
thanks a lot
thanks a lot
thanks a lot
you need to switch over the fuel pump wire along with the fan switch, its pretty simple, download a stock wire diagram for both EvoV and Evo8. That will show you which wires are to be changed. Also, if you are planning on running SD you will need to wire in the map sensor.
Ad-Rok
Apr 2, 2014 12:54 PM
cuscoevo
Mar 22, 2013 01:17 PM
bttkcooled
Apr 17, 2007 06:48 PM
