4G15 Timing belt change instructions?
Hey guys, just posting here to get help with a 4G15 SOHC timing belt change. Anyone happen to have PDF/JPG/Webpage of timing belt change?
I've snapped the timing belt while driving, and decided to try to install the timing belt and see if it runs. The timing belt snapped at TDC (its where the cam pulley was pointing at when i checked after the timing belt snapped).
load on the crank seems fine, as I've tried turning it with and without spark plugs, it made a big difference.
I've already put everything apart, and currently waiting until tomorrow because when I took off the water pump (being changed while at it), it splashed the bottom and side part of my engine pretty good. Wiped off most of it, but just want to make sure everything is dry.
I basically need to know how the Timing belt tensioner functions, it seems very straight forward with a coiled spring. But it'd be nice if I can get TQ specs for each bolts.
Sorry for long post, Thanks!
warstang27
Nov 3, 2015 10:30 AM
vtluu
16
Jan 8, 2011 07:57 AM
Mhac
Mar 16, 2009 03:15 PM
KevOVIII
18
Nov 10, 2005 08:05 AM
