ECUFlash / Evoscan / Mitsulogger Questions
#1576
Anyone know if Evoscan will run on a Windows CE6.2 device?
#1578
#1579
hello , could anyone confirm this?
i have an openport cable 1.3 , and the white reflash connector is different in the outlander , it wont fit , it has two wires one green/yellow and one purple , which one should i splice and connect to the openport cable?
in this thread one guy said its the green wire
https://www.evolutionm.net/forums/ot...l#post11275212
my outlander has an evo 8 ecu and evo 8 motor , which ecu pin corresponds to the white/reflash connector single cable in an evo 8 ecu , so i can trace it back to the ecu if my connector is wrong?
thanx
thanx
#1580
https://docs.google.com/file/d/0B0k8...9uXzk3MGM/edit
I just got my Tactrix cable in the mail and so far works perfectly.
I read my rom. Does this look stock? Reason I ask is the speed limiter. Thought it was supposed to be lower than 510. Makes me wonder if my car is less than the stock I was led to believe. I hope this link works.
Thanks for any input.
#1581
#1583
Give me your email and I will send you my ROM, you will see better than me definitely. Only what I know it seems that function doesn't work anyone
#1585
having problem with evoscan starts loggin then stops v2.9.0092 Evo 8 2003
what could it be?
uninstall evo sacn and installed it already....
I was told not to take pin 9
anyhelp
what could it be?
anyhelp
#1586
I need help, I tried to get my Omni 4 Bar to start logging on EvoScan and I have the setting all correct from what the tuner said but I have not got it to start logging. I am using the 4 bar and have the gauge reading -30 and max is 50 as I am using a AEM 50psi Boost gauge. Can someone help me with what I could be doing wrong. I am using EvoScan 2.8 as I was having issues with 2.9
RequestId-38
Eval-0.2369*-14.7
Unit-psig
Response bytes-1
Gauge Min=-30
Gauge Max=50
Chart Min=-30
Chart Max=50
Scaling Factor=1
RequestId-38
Eval-0.2369*-14.7
Unit-psig
Response bytes-1
Gauge Min=-30
Gauge Max=50
Chart Min=-30
Chart Max=50
Scaling Factor=1
#1587
RequestId-38
Eval-0.2369*-14.7
Unit-psig
Response bytes-1
Gauge Min=-30
Gauge Max=50
Chart Min=-30
Chart Max=50
Scaling Factor=1
RequestId-38
Eval-0.2369*-14.7
Unit-psig
Response bytes-1
Gauge Min=-30
Gauge Max=50
Chart Min=-30
Chart Max=50
Scaling Factor=1
These settings look good for Omni4 and Evoscan.
Have you checked:
(a) MUT38 table entry in your ROM - The address may be wrong. Go to Google and search for the following: evom (your rom id #) mut table
That should get you the address you need in MUT 38. If not, post your rom id and we can help you find the right address. If the MUT38 address is wrong correct in ECUFlash and flash it back to your ECU.
(b) If the MUT38 address is correct for your ROM it means you are not getting a signal from sensor to the ECU.
Throw a volt meter across the sensor plug to see if you are getting 5V to the sensor. Check the continuity of the signal cable back to the ECU input pin.
Check the voltage at the ECU pin from the sensor - should be around 2V.
(c) If the signal is good at the ECU input pin, then it means the ADC input circuit is fried on your ECU. Find an alternate ADC input on a different pin that is not being used. Rewire sendor, change MUT address to read that ADC input and you are done.
#1588
Have you checked:
Have you checked:
#1590
That correct, when I was reading I was missing one part to the Equation from what I can see. My code currently is 0.2369*-14.7 and it needs to be 0.2369*x-14.7 if I am reading everything correctly.
