EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Jun 29, 2009, 04:22 AM
  #751
travman's Avatar
Originally Posted by claudiumxg
evoscan stops working randomly, logs very slow, and can't log acd/ayc , can't enable acd/ ayc actuators on evo 8 jdm, (op 2.0 windows xp) 2.6 v14
get v15 - see page 1
Old Jun 29, 2009, 10:04 AM
  #752
Mellon Racing's Avatar
Originally Posted by SiC
Right, but the new Openport 2.0 drivers may help in the issues with Evoscan.
man that would be great if this does the trick for ecuflash and evoscan on my x86 vista laptop
Old Jun 30, 2009, 07:47 PM
  #753
EvoX_SA's Avatar
Evoscan is pissing me off. I have made 20 damn logs just fine, but it won't let me freaking access them through windows. Everytime I go into SavedDataLogs there isn't anything there but Sample logs. When I open EvoScan it says "Running Windows Vista Only Read Access - Folder permission updated Successfully" But it will let me view them in evoscan. What the hell is going, someone help me before I throw is laptop out the damn window.
Old Jun 30, 2009, 09:17 PM
  #754
D-VO's Avatar
What's up man. Did you try to click on the "logging" tab then the "explorer"? All your logs should be in there.
Old Jul 1, 2009, 11:21 AM
  #755
evo4mad's Avatar
2nd July 2009: EvoScan v2.6 Beta16 released! see Post #1
- FULL support for evo7/8/9 and openport2 USB cables.
- MUTII DTC support for op2
- OBDII DTC support for op2
- MUTII Actuator Support for op2
- Fixed openport2 freeze when vehicle was not plugged in.
- Minor Map Tracer enhancements.
- Minor Power graphing enhancement.
- Faster op2 datalogging
- Disabled multithreading by default. (enable this from the logging menu if you want a more responsive UI)
- removed evo7/8 rom hex files to decrease the download installer file size.
Old Jul 1, 2009, 02:16 PM
  #756
dolphin888's Avatar
DTC check/clear works perfect with OP2!
BTW: Does EvoScan touchscreen device support lambda wideband input via USB??
Old Jul 2, 2009, 05:13 AM
  #757
tsitalon1's Avatar
Both DTC Check and DTC Clear working with Beta 16 on Evo X??? If so, I guess I better download it..
Old Jul 2, 2009, 09:49 AM
  #758
evo4mad's Avatar
you need to read more carefully, it says OBDII and MUTII DTC check and clear, it also says CAN EVOX dtc clear is work in progress.
Old Jul 2, 2009, 01:33 PM
  #759
D-VO's Avatar
Hey Hamish:
There was two small problems that I've found while using the 2.0 cable. The first one I found is the acd error (three flashing lights). This happens when the car is started after evoscan is stared. Is this supposed to happen for a test or something?
The second is the actuator tests don't work with 2.0 cable. This was tested on an 03 and o5 EVO.
BTW: Props for 2.0 for the subies! I haven't tested this yet though.
Thanks a lot for all your hard work man!
Old Jul 2, 2009, 01:36 PM
  #760
TTP Engineering's Avatar
The lights are supposed to flash on the Evo 8-9 ACD car, once a speed threshold is met, it turns off.
Old Jul 2, 2009, 03:23 PM
  #761
D-VO's Avatar
Oh? But, my acd lights will keep flashing no matter what speed. The lights will stop flashing when I stop evoscan. Then when I start evoscan back up, the lights will stay off. Is that whats supposed to happen?
Wow...never noticed this.
Thanks
Old Jul 3, 2009, 05:15 AM
  #762
it's not hurting anything
Old Jul 3, 2009, 01:12 PM
  #763
D-VO's Avatar
I just imagine it meaning that my acd isn't going to work if I have evoscan running.
Old Jul 3, 2009, 03:05 PM
  #764
philr8's Avatar
Originally Posted by D-VO
Hey Hamish:
Just tried it on an 08 STI with open port 2 and it doesnt work
Old Jul 4, 2009, 10:01 AM
  #765
hameedosh's Avatar
hi hamish
been trying beta 16 on my evo x, its looking good but with the following issues
its a little bit slow
the throttle position is stuck on 100 (on USA evo works fine)
the external wideband AFR stops reading after 3 frames or so
Quick Reply: EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
